EZ-B V3 Configuration icon EZ-B V3 Configuration — Manage EZ-B hardware settings: edit Bluetooth name and apply updates to restore altered configurations. Try it →
#25
See my edit above for an important additional message.
As far as the extra wire: that's the signal wire that go directly from the outside pin of one digital port of the EZB to the servo signal wire. You run the power wires (+ and -) from your power source (the EZB it's self or and external power supply like a battery) through this unit and to the servo.
How many Amps are in a volt? or is that even correct? (ps, sorry about all the questions)
#27
Two different things. Simplistically, The amps are the power (electrons) that runs the motor and the voltage is the pressure that pushes the electrons through the circuit. Imagine shaking up a bottle of soda and uncorking it. The Amps would be the soda and the pressure pushing it out of the bottle would be the voltage. There's really a little more to it then that but you should get the idea for this description. It's really not a compacted theory and one worth learning about. ;)
