Soundboard (EZB) icon Soundboard (EZB) — Play WAV/MP3 via EZ-B v4, manage tracks, add timed scripts for synced robot actions, control via ControlCommand(), volume and clipping indicators. Try it →
Can't Hook Ezb4 To Network
I have an ezb4 that has worked fine for a while. I had took the robot apart and then put it back together using the V4 instead of V3.
My problem is: I go to find the ezb in the internet access window. I have reset it many times.
I have to give it a code 1234 to hook up to bluetooth. well, I found that I lost ports for Com3, and Com4. So I added them back. My device shows up, but I have a hard time getting to the part that says are you ready to pair?
If I enter in the correct number, it goes out a trys to pair it, it times out and I have to start all over again.
The green light is on and it continuously blinks. There is no red, or whatever. Just a blinking green light.
I have taken everything apart and now my time has run out. I will be back Tues CST to work on it again. I have the unit hooked to a separate 12vdc battery so it will have plenty of juice. There is a constant blinking green light.
Also, there is no sound at all.
thanks in advance.
#17
@moviemaker, try it this way, turn your power off on the ezb4 Press the reset button continue to hold the reset button and power on the ezb4. continuing to hold the reset button for eight seconds then release see if it goes back to blue light blinking
#18
@mel, did my last post work?
can you try to connect first with an android or iphone? then pc
#21
my wife won't let me use her iphone, but I have an android device. I will try to hook up.
. . . . . . Nope. I don't see the device in the list. same way one the desktop. It used to show up as EZB .....something, something, something.
I believe the wifi part of the V4 has gone bad. Or possibly the firmware. I don't have a proper flasher or image.
do you know how to delete your browser history?
