Text Overlay icon Text Overlay — Overlay a variable on a processed camera image at X/Y coordinates; name the variable and attach to a specific or any available camera Try it →
Can't Hook Ezb4 To Network
I have an ezb4 that has worked fine for a while. I had took the robot apart and then put it back together using the V4 instead of V3.
My problem is: I go to find the ezb in the internet access window. I have reset it many times.
I have to give it a code 1234 to hook up to bluetooth. well, I found that I lost ports for Com3, and Com4. So I added them back. My device shows up, but I have a hard time getting to the part that says are you ready to pair?
If I enter in the correct number, it goes out a trys to pair it, it times out and I have to start all over again.
The green light is on and it continuously blinks. There is no red, or whatever. Just a blinking green light.
I have taken everything apart and now my time has run out. I will be back Tues CST to work on it again. I have the unit hooked to a separate 12vdc battery so it will have plenty of juice. There is a constant blinking green light.
Also, there is no sound at all.
thanks in advance.
#25
I was clearing the cache. I had a LOT of stuff.
OK, cache is cleared. Now what?
did you connect with your phone?
#27
Nomad, If he can't see the EZ=B network, it has nothing to do with browser history or cache.
I do believe he is correct that the EZ-B WiFi may be broken.
Mel,
Try opening the case, and carefully separate the two boards and push them back together. Sometimes re-seating the boards can help.
I have a firmware flasher if you want to send the board to me for troubleshooting. I think you still have my address. Email me if not.
alan
i had a problem long time ago,it also didn connect.some one told me to do this, and he did connect.thats why i ask to try connect with a phone,first steps i believe.
#29
OK, after that, I will take Sally apart and forget the robot business until I can buy one already factory assembled and with ALL the software.
Thanks! Alan, you are such a nice guy. I already took it apart. But, I did not separate the two boards.
#30
Mel,
If you do send me the board, also send me your router's SSID and password, and I'll pre-configure it to connect to your network so you don't need to go through that again. Only think we may need to do is log into the router to reserve the IP address because if I determine it is the WiFi and not the main processor board, I will send you one of my other EZ-Bs and when EZ-Robot releases the 4.x/2 com board upgrade I'll replace the WiFi board with that.
@Nomad,
That could cause problems connecting to the EZ-B's web page, but would not prevent you from connecting the the WiFi network. Similar problem, but different.
thanks for telling.does he dont need to remove the com ports he made with that bluetooth?
