Ohmnilabs Standalone icon Ohmnilabs Standalone — Connects Ohmnilabs Telepresence robot's UP Board COM to ARC, enabling drive and servo control (neck V0) and integration with ARC cameras. Try it →
Can't Hook Ezb4 To Network
I have an ezb4 that has worked fine for a while. I had took the robot apart and then put it back together using the V4 instead of V3.
My problem is: I go to find the ezb in the internet access window. I have reset it many times.
I have to give it a code 1234 to hook up to bluetooth. well, I found that I lost ports for Com3, and Com4. So I added them back. My device shows up, but I have a hard time getting to the part that says are you ready to pair?
If I enter in the correct number, it goes out a trys to pair it, it times out and I have to start all over again.
The green light is on and it continuously blinks. There is no red, or whatever. Just a blinking green light.
I have taken everything apart and now my time has run out. I will be back Tues CST to work on it again. I have the unit hooked to a separate 12vdc battery so it will have plenty of juice. There is a constant blinking green light.
Also, there is no sound at all.
thanks in advance.
#57
@moviemaker, I replied to your e- mail, if you call At 4 your time would be ok, if not then you would have to call me after 4PM your time. Darn work gets oin the way, but it pays the bills and all:)
#58
I was talking about 4 AM. I am usually in my office from 4-7am to 11:00 AM. The rest of the day, my wife has me for errands and empty the trash and more.
Here is my status. I have it all hooked and it is working fine. I can control the EZB from my desktop. It is hooked to the router which is hooked to the net.
The only thing, once it is operational, I want to hook it to my desktop and save the program and then install it on my notebook. Once it is there, I want to control the notebook through Teamviewer or such from my desktop and also hook to the net. But, I want to do it all at the same time. I have done this before. But, I believe in order to do both of them at once, I need to be in Client Mode.
Correct me if I am wrong.
oh, BTW, @nomad, Thanks for trying to help me. I forgot to thank you when I thanked the others.
@merne, so, I am not in a rush. I have to wire all the other stuff up first.
your welkom,all is fine.
#60
Mel,
If it is hooked to the router, and you can see it from your desktop, you are already in client mode (I shipped it to you in client mode with your router credentials, so if you didn't hit the reset button, that is how it would have come up - assuming you provided the correct SSID and password).
You don't need to do anything additional except save your project to the notebook and start teamviewer. You can either move the project through file sharing on your network, with a thumb drive, or save it to EZ-Cloud from the desktop and download from EZ-Cloud on the notebook.
Gotcha. God Bless You for all of your help.
The EZB is working perfect and connecting up automatically. I think I gave it the wrong password and that is why I am not in client mode. But, I have everything but the Hbridge tested. But, I have wired them all up on the robot. So, wish me luck. I will keep you enformed. New Life is brewed into sally.
MovieMaker
great work bolt of you.
#63
Ok, I am very happy to announce that the EZB 4 is working fine. And, I have completely rewired Sally and I am back to where I was at the beginning.
#64
OOOoops! I think I posted in the wrong place. Please feel free to move it.
