Read Digital icon Read Digital — Read TTL digital input from an ARC I/O port; real-time red/green status for low (0V) or high (+3.3/5V), selectable board/port and read interval. Try it →
Can't Hook Ezb4 To Network
I have an ezb4 that has worked fine for a while. I had took the robot apart and then put it back together using the V4 instead of V3.
My problem is: I go to find the ezb in the internet access window. I have reset it many times.
I have to give it a code 1234 to hook up to bluetooth. well, I found that I lost ports for Com3, and Com4. So I added them back. My device shows up, but I have a hard time getting to the part that says are you ready to pair?
If I enter in the correct number, it goes out a trys to pair it, it times out and I have to start all over again.
The green light is on and it continuously blinks. There is no red, or whatever. Just a blinking green light.
I have taken everything apart and now my time has run out. I will be back Tues CST to work on it again. I have the unit hooked to a separate 12vdc battery so it will have plenty of juice. There is a constant blinking green light.
Also, there is no sound at all.
thanks in advance.
#49
Jesus @mel this is just not working for you. It's been nearly 2 years since the ezb4 has been released and you still struggle just getting it even connected... Maybe it's time for a new hobby, man?
One last time... This is not hard and as usual you over analyzing everything... Forget about what your router is doing or not doing...
If your ezb4 is connected through your router you are in "client mode" (Green LED)... if your ezb4 is connected directly to your PC you are in "WP mode" (Blue LED)...
Write this Down and stick it on the wall in front of you..
Flashing blue = WP mode... NOT connected to ARC Solid blue = WP mode... connected to ARC
Flashing green = Client mode... NOT connected to ARC Solid green = Client mode... connected to ARC
Sorry man, not trying to be rude here,.... but this has to stop at some point... We keep going around and around here like the movie Ground Hog Day...
green led and text in ezb that tels you i have sucsesfull connected to your network
client mode on the web page is just under ap mode.
#51
OK , right now , I have a solid blue light. That tells me I am in WP mode, right? Now I need to get to client mode. I just have to play with it because I know where to change it. I went through the procedure earlier and it did not change from blue. I just need to go over it again.
richr, thanks for your help.
do you have a cell phone,go to 192.168.1.1 put in your ssid and password. and connect,you will see message conention will be lost but the led goes to green. blinking.you also hear message am sucsesfull connected to your network. then op ARC and use the scanner,when connected save in cloud.
#53
@Mel, I assume you have a computer with Wi-Fi right ? Turn on the ebz4 you Will hear a chime and it should be blinking blue. Open up your Wi-Fi icon on your computer you will see the ezb inside there. Click on connect and you should be connected to it now.
wait let's do it this way can you post your email address and I will email you later today with my phone number and I can walk you through on the phone
#54
Thank You, Merne.
I will not be back until tomorrow because I have a lot of honeydos to do. I will be back from 4-7 am CST.
My email is yhmmc<at>yahoo,dot<dot>com
#55
@Mel, I just sent you an email talk to you tomorrow
#56
@merne, it is possible that my wife has my schedule lined up for trips to town. I will be here early (4-7amCST) possibly. I usually work from 4 to 11, then I go eat at 11:00 am , and I am back home at 12:00 noon to do her stuff. But, I think she has plans for me before noon this time. I will send you an email and see when we can meet. Thanks for your help.
