Just got an EZ-Robot and battery won't charge and LED flashes red 6 times. Is this defective? How do you fix?
Ashton
— Edited
5 Participants
Wowwee MIP V2
— UART interface to hack WowWee MIP with ESP32/ESP32‑Cam or EZ‑B v4 for ARC; hardware UART preferred, configurable power and baud 9600/115200
https://synthiam.com/Tutorials/Lesson/26?courseId=3 but doesn't sound right
It means that there is a 300mv difference of voltage in the battery pack. Please fully charge battery and hopefully it will be ok.
this pic wil help
Ok, there's a 300mv difference. Now what? Do you throw it away? Check the wiring? Bang it against a table? Swing it around your head and chant "Owa Tagoo Siam"? What? The instructions seem to fail at that point. They just say to stop charging it. Not very helpful.
do you have another batt that you can charge to see if charger does desame or not. if not i gess the batt is bad.
It means it is defective. I did some google searches and there are some r/c people who used a meter to find out which cell was low and eiher charged just that cell up until the voltage was closer or discharged the high cell (connected a motor or other circuit for a while) then when the cells where even out it back on the balance charger. Some had success but all warned it was risky due to the fire hazard.
Since the battery is brand new (and I assume you didn't abuse it by letting it discharge past the low battery warning of your bit) I would make a warranty claim on the Contact Us page. Reference this thread to ahow them you have received community advise.
(if you did run the battery to 0, replacements are not expensive)
I took apart the robot and disconnected all the cables. Once that was done, I attempted to charge the battery and the charger looks ok and normal. I no longer see the error.
The error message does not provide much troubleshooting info, and it does state to unplug the battery from the charger.
This was my first time charging the battery, so if it is bad it is defective.
So you're saying that after fully charging the battery everything works now?
