Just got an EZ-Robot and battery won't charge and LED flashes red 6 times. Is this defective? How do you fix?
Ashton
— Edited
5 Participants
PTI Lidar Plugin
— Pineapple Technology Industries Capstone plugin adds a secretive LiDAR unit to ARC for distance measurement.
After I disconnected all connections and just have the battery attached to the charger, the battery now charges and everything works.
Fantastic. I suspect it will work fine from now on in the normal configuration. Probably came from the factory with one of the cells not fully charged.
All cables were disconnected and battery was able to charge correctly. All works fine now.
