Dual Hbridge W/PWM icon Dual Hbridge W/PWM — Dual H-Bridge w/PWM movement panel: control two DC motors' direction and speed via EZ-B PWM for responsive forward/reverse/turning. Try it →
ChatGPT Skill Response Delay Issue
Chatgpt Skill Response Delay Issue
I have a question regarding the OpenAI ChatGPT robot skill in Synthiam ARC.
When I use Bing Speech Recognition in conjunction with the ChatGPT skill, activated by a wake word, the responses seem to be consistently one question behind.
Why is there a delay or silence when I ask the first question?
Additionally, why does it respond to the first question only after I have asked a second question?
How can I resolve this issue so that the system answers the correct question in real-time?
EZ-Inmoov Robot Head by EZ-Robot & Gael Langevin
EZ-InMoov Robot Head with Synthiam ARCx: face tracking, speech recognition, Talk Servo jaw motion and AI conversation
Servos 8
ADC 2
Digital 8
Configure Windows Audio.say()/Audio.sayEZB() TTS on EZB#0: voice, emphasis, rate, volume, speed/stretch and audio effects; copy control script.
ChatGPT chatbot for robots with memory, image description, personality scripting, and voice conversation via OpenAI API
#1   — Edited
If you could share the code you have in the robot skills, that would be useful. Otherwise, it's a guessing game:). I can't think of why the GPT responses could be one behind. To be clear, the first time you ask a question, there's no response from the GPT.
Post the code that's in each of these (and please format the code that you paste into the response so it can be read, thanks)
  • bing speech recognition "any recognized" script
  • Open AI Chat GPT "response" script
Post the code from those two robot skills so it can be better understood what you have configured
To address the issue of the OpenAI ChatGPT robot skill responding one question behind, let's first ensure that the scripts in both the Bing Speech Recognition and OpenAI ChatGPT skills are correctly configured. Please follow these steps:
  1. Bing Speech Recognition - All Recognized Script:
    • Ensure that the script sends the recognized speech to the OpenAI ChatGPT skill immediately after recognition.
    • Here is an example of how the script should look in JavaScript:
    // Send the recognized speech to OpenAI ChatGPT
    ControlCommand("OpenAI ChatGPT", "Send", getVar("$BingSpeech"));
  2. OpenAI ChatGPT - Response Script:
    • Ensure that the response from the ChatGPT skill is processed and spoken immediately.
    // Speak the response from OpenAI ChatGPT
    Audio.say(getVar("$OpenAIResponse"));
  3. Check for Delays:
    • Ensure there are no unnecessary delays or sleeps in the scripts that could be causing the response to be delayed.
  4. Test the Configuration:
    • After making these changes, test the configuration by asking a question and observing if the response is immediate.
  5. Debugging:
    • If the issue persists, consider adding print statements to debug and see where the delay might be occurring. For example:
    // Debugging: Print the recognized speech
    print("Recognized Speech: " + getVar("$BingSpeech"));
    // Debugging: Print the response from OpenAI ChatGPT
    print("ChatGPT Response: " + getVar("$OpenAIResponse"));
By ensuring that the scripts are correctly configured and there are no delays, the system should respond to the correct question in real-time. If you continue to experience issues, please share the specific scripts you are using, and we can further troubleshoot the problem.
Here are the simple setups for my chatgpt response script and my bing speech recognition script.
Still not sure what I need to add to fix this issue.
#5   — Edited
The issue is that you have the same code in both robot skills. You're speaking the response from open ai in both robot skills.
  1. In the bing speech recognition robot skill you should be pushing the text to the gpt robot skill
  2. In the gpt robot skill you should be pushing the text to the azure text to speech robot skill.
Look at it this way...
You need to LISTEN before you can THINK before you can SPEAK. Make sense?
LISTEN = bing speech recognition THINK = gpt  SPEAK = azure text to speech
  1. So in Bing speech recognition, send the response to the open AI
  2. in open AI, send its response to azure text-to-speech
You can right-click in the editor or use the Cheat Sheet to see the available control commands. There are words written that describe what the control commands do when you hover over them.
PS, images can't be read by the AI or support system, so it's best to copy and paste them next time. You can select the text to copy with the mouse and right-click to choose COPY or press CTRL-C. That will copy the text to the clipboard. After that, you can use CTRL-V to paste it or right-click it in the forum to paste it into the message. There are buttons at the top of the editor for formatting code. It is like how Microsoft Word, Google Docs, Email clients, etc, work. Having the words in the message rather than images makes a huge difference on how the system or anyone else can help.
@Athena do you have anything more to add?
Certainly! Let's break down the steps to ensure your setup is correctly configured for seamless interaction between Bing Speech Recognition, OpenAI ChatGPT, and Azure Text-to-Speech:
Step-by-Step Configuration
  1. Bing Speech Recognition:
    • Script for All Recognized Speech:
      • Ensure that the recognized speech is sent to the OpenAI ChatGPT skill.
      • Example JavaScript code:
        ControlCommand(OpenAI ChatGPT, Send, getVar($BingSpeech));
  2. OpenAI ChatGPT:
    • Response Script:
      • Ensure that the response from ChatGPT is sent to Azure Text-to-Speech for speaking.
        // Send the response from OpenAI ChatGPT to Azure Text-to-Speech
        ControlCommand(Azure Text-to-Speech, Speak, getVar($OpenAIResponse));
  3. Azure Text-to-Speech:
    • Ensure that this skill is configured to receive text and convert it to speech.
Debugging Tips
  • Check for Delays:
  • Test the Configuration:
  • Debugging:
    • Add print statements to debug and see where the delay might be occurring.
    • Example:
      print("Recognized Speech: " + getVar($BingSpeech));
      print("ChatGPT Response: " + getVar($OpenAIResponse));
Additional Considerations
  • Ensure Correct Order:
    • The flow should be: Listen (Bing Speech Recognition) Think (OpenAI ChatGPT) Speak (Azure Text-to-Speech).
  • Control Commands:
    • Use the right-click menu or Cheat Sheet in ARC to find and use the appropriate control commands for each skill.
By following these steps, you should be able to resolve the issue of delayed responses and ensure that your system answers the correct question in real-time. If you have any further questions or need additional assistance, feel free to ask!
#8   — Edited
Sorry I posted the same screenshot twice in my previous comment.
Bing Script:
ControlCommand("OpenAI ChatGPT", "Send",getVar("$BingSpeech"));
ChatGpt Script:
ControlCommand("Azure Text To Speech", "speak", getVar("$OpenAIResponse"));
