Picture In Picture icon Picture In Picture — Picture-in-picture camera overlay: superimpose one camera onto another; configure source/destination, position, size, border, processed frames, and swap Try it →
ChatGPT Skill Response Delay Issue
Chatgpt Skill Response Delay Issue
I have a question regarding the OpenAI ChatGPT robot skill in Synthiam ARC.
When I use Bing Speech Recognition in conjunction with the ChatGPT skill, activated by a wake word, the responses seem to be consistently one question behind.
Why is there a delay or silence when I ask the first question?
Additionally, why does it respond to the first question only after I have asked a second question?
How can I resolve this issue so that the system answers the correct question in real-time?
EZ-Inmoov Robot Head by EZ-Robot & Gael Langevin
EZ-InMoov Robot Head with Synthiam ARCx: face tracking, speech recognition, Talk Servo jaw motion and AI conversation
Servos 8
ADC 2
Digital 8
Configure Windows Audio.say()/Audio.sayEZB() TTS on EZB#0: voice, emphasis, rate, volume, speed/stretch and audio effects; copy control script.
ChatGPT chatbot for robots with memory, image description, personality scripting, and voice conversation via OpenAI API
#17
Some things aren't adding up with these details lol, I'm confused. The code you posted above is...
Bing Script:
ControlCommand("OpenAI ChatGPT", "Send", getVar("$BingSpeech"));
ChatGpt Script:
ControlCommand("Azure Text To Speech", "speak", getVar("$OpenAIResponse"));
Your project has the following robot skills.
9 robot skill(s) to page 0:
- ARC.UCForms.FormConnection (Connection)
- ARC.UCForms.FormCameraDevice (Camera)
- ARC.UCForms.FormBingSpeechRecognition (Bing Speech Recognition)
- ARC.UCForms.FormAutoPositionerNoMovement (Auto Position)
- ARC.UCForms.FormScriptCollection (Script Collection)
- ARC.UCForms.FormSpeechSettings (Speech Settings)
- ConversationalMenu.MainForm (Conversational Menu)
- AzureTextToSpeech.MainForm (Azure Text To Speech)
- OpenAIChatGPT.MainForm (OpenAI ChatGPT 2)
8 robot skill(s) to page 1:
- ARC.UCForms.FormServo (D0 - Eye Tilt)
- ARC.UCForms.FormServo (D1 - Eyes pan)
- ARC.UCForms.FormServo (D2 - Jaw)
- ARC.UCForms.FormServo (D3 - Head pan)
- ARC.InterfaceBuilder.FormInterfaceBuilder (My Mobile Interface)
- ARC.UCForms.FormSoundServoEZBv4 (Sound servo v4)
- ARC.UCForms.FormSoundBoardEZBv4 (Soundboard v4 2)
- ARC.UCForms.FormSpeechSynthesis (Speech Synthesis)
At some point, you had added 2 openai chat gpt skills, removed one, and kept the one with the 2 on the end. But the code you posted references 'OpenAI ChatGPT' and not 'OpenAI ChatGPT 2'.  The ControlCommand in the code you provided does not reference 'OpenAI ChatGPT 2'. I'm not sure how what you have even works at all. haha
@Synthiam_support, we need an update to ARC that displays the version of the robot skill plugins in the debug to clarify better what users have going on. We don't know what version the robot skills are or if they're the newest. I'm guessing not, but I also can't understand how this project even works
@Chris, with what you have posted, I don't see how it can work at all, let alone partially work. Can you share your project? That's the easiest then I can tell you how to fix it. My first suggestion is to remove the 'OpenAI ChatGPT 2' and add a new one so it has the correct name 'OpenAI ChatGPT' used in your ControlCommand scripts.
But again, I just can't understand how it works at all when the robot skills in the ControlCommand is named entirely different. haha is it April 1st?:D
#18
@Chris, can you post the project file either by saving it to the cloud and making it public or uploading it here using the FILE option in the editor?
If you do not want your project shared, you can create a new project that demonstrates the same behavior and share it using either method.
#19
That Is a pretty fair assessment. I really appreciate the help and responsiveness.  I definitely got excited and dove in headfirst. I've added and removed a ton of skills over and over again. To my detriment I tend to get my hands dirty and learn by trial and error instead of reading documentation and going through the proper tutorials, so It is no Suprise that everything can be a bit of a mess.
I think what I will do is just scrap the project version and build a new one from scratch with lessons learned and see if that resolves things.
Completely unrelated question: I am using an EZB ioTiny setup in client mode. When I try to use the EZ-B connection skill to scan the network I can never see it and I just enter the IP address manually after looking it up on my router. It goes right though the range but doesn't see it, It should be broadcasting its presence? But I can't see any option on its setup page that explicitly says so. Not sure if there is an issue with the EZ-B not broadcasting or with the skill not picking it up.
#20
I saved project to synthiam cloud as "AI_TESTBED_Chris"
#21
I don't see the project AI_TESTBED_Chris. Is it saved as public? Due to privacy restrictions, we can't see apps that aren't marked as public. They're not accessible by anyone unless they're public.
#22
I think it is public now. Just has one tag for "incomplete"
#23   — Edited
Oh this is easy.  Your script is in the "Start Listening" for Bing Speech Recognition.
  • "Start Listening" will execute a script when the robot skill begins to listen.
  • "Any Recognized" will execute when the speech is converted to recognized text.
The script is in the wrong place:)
#24
I'll add a few tips for ya as well.
  • you have the chat gpt robot skill configured to use the Azure Text To Speech, which is great. But you also have the speech settings robot skill added. Just know that the speech settings only work with the internal "robotic" Windows voice that you get when using the Audio.say() and Audio.sayEZB() commands. https://synthiam.com/Support/Skills/Audio/Speech-Synthesis-Settings?id=16054
  • In the auto position, some scripts can run for each action. The button is red when a script is added to it. The scripts currently use the "Audio.say()" commands. So, the voices between Auto Position and gpt will be different. You'll want to edit those and move them to the ControlCommand for the Azure text-to-speech if you wish to have the voices the same.
