TCP Clients icon TCP Clients — Monitor incoming TCP Server connections when TCP Server is enabled under Connection > Config; view and track live connections. Try it →
Resolved Resolved by ptp!
Configuration Form When Creating A Plugin
I have went thru the tutorial for the plugin and have successfully created a basic plugin. Now I want to go the next step and create a plugin that has a configuration page that is accessed by clicking the gear icon but can not figure out how to do it.
The plugin I hope to create will allow the user to create a connection to a database using a DSN.
RichardZ
Update: One Step Closer - I found the UCConfigurationButton
Update2: Stumbled upon ptp's testplugin on github and creating a ConfigForm.cs using it as my example.
@DJ, Thank you DJ that now makes sense. I will look when I get home this evening.
@ptp, Thank you so much. I will study the code and add to my plugin project as a learning experience.
I will post how it all goes on Thursday after the site comes back up.
RichardZ
@ptp, I tried your plugin and all I can get is the number of hits the query received not the actual data.
$Connection = "System.Data.Odbc|DSN=EZBrain;"
$sql = "Select MemoryName from MemoryAtom where MemoryType = 1"
$Results = DataQuery($Connection, $sql)
print($Results)
Start
> 97
Done (00:00:00.1249936)
Check the last example.
The function returns the number rows.
Your data is in the array variable $data_0
Add the variable monitor control and you will see the data there.
AWESOME! Thank you I looked at all examples but that one was using a different data provider so I just looked over that.
This is great ptp, thank you so much. when I complete the database brain I owe you a copy.
RichardZ
#29   — Edited
@ptp,
When trying to insert a record using
$sql = "INSERT INTO MemAtom (MemType, MemData) VALUES (7, '" + $varSTR1 + "')"
$varSTR1 equals one of the 2 lines.
The first line inserts correctly, the second gives me an error Syntax error (missing operator).
  1. All the men of thy confederacy have brought thee even to the border: the men that were at peace with thee have deceived thee, and prevailed against thee, that they eat thy bread have laid a wound under thee: there is none understanding in him.
  2. All the Nethinims, and the children of Solomon's servants, were three hundred ninety and two.
I wrote a VBScript to do the same thing and get the same result that tells me it is not a bug but something with my insert statement but I can not figure it out.
I can paste the line into the database just fine.
Any guess as to what my issue is? with the insert statement I mean.
RichardZ
#30   — Edited
@rz90208:
SQL Strings use single quotes. If your $varSTR1 contains a single quote will break the query.
That is the reason why I've implemented parameterized queries, at least for strings and numbers it will work (ez-script supported types).
using a parameterized query parameter @0:
$sql="INSERT INTO Table1([Str1]) VALUES(@0);"
$string1="Test is a test"
DataQuery($connection, $sql, 10, "$myData", $string1)
$string2="For 'single quotes' you will need parameterized queries."
DataQuery($connection, $sql, 10, "$myData", $string2)
PS: The forum is still in beta mode and is crippled i know the things will be fixed soon or later, for faster responses drop me an email : tiago.private AT gmail.com.
@ptp
That worked. I edited my source document and changed all ' to nothing saved the doc and all imported without error.
Not the best solution but will work. I don't think the robot will speak the word any different
Servent's or Servents
Thank you again
@PTP is this addon still working? I get an error when trying to use in.
print($Results)
Start
Error on line 3: Unknown function: DataQuery. Done (00:00:00.0048909)
