Blinkm icon Blinkm — BlinkM I2C multi-color LED control with slide dials for custom colors; supports SendI2C for custom I2C peripherals. Third-party device. Try it →
Resolved Resolved by ptp!
Configuration Form When Creating A Plugin
I have went thru the tutorial for the plugin and have successfully created a basic plugin. Now I want to go the next step and create a plugin that has a configuration page that is accessed by clicking the gear icon but can not figure out how to do it.
The plugin I hope to create will allow the user to create a connection to a database using a DSN.
RichardZ
Update: One Step Closer - I found the UCConfigurationButton
Update2: Stumbled upon ptp's testplugin on github and creating a ConfigForm.cs using it as my example.
closed ARC, reopened, started a new project and tried to add the Misc. Utility and I get the does this plugin need an update error message.
#34   — Edited
It needs to be updated to ARC! I'll do it later tonight.
Thank you so much. My robot is speechless.
Thank you ptp I have it reinstalled and it works as expected. Now if I can only remember how to phrase the Select statement correctly for MS Access.
RichardZ
As I said before it is working great, except I have run in to a snag. When a new query is run, it does not clear the data from the previous query. So if my query returns less data then the previous query I have garbage left in the array. doing a ClearVariables() before each query would work if I didn't mind losing all my other variable data, which is not an option.  My current workaround is to always look at the reported Array size and just ignore the garbage data.
