MPU6050 Accelerometer Gyro Temperature icon MPU6050 Accelerometer Gyro Temperature — Reads MPU6050 gyro, accelerometer and temperature via I2C, initializes and returns data on-demand to EZ-Script variables using ControlCommand RunOnce Try it →
Connecting EZ camera to PC via USB
Connecting EZ Camera To PC Via USB
Is is possible to connect the EZ camera to a PC via a USB port? Or is it easier to buy another one such as... https://core-electronics.com.au/usb-camera-for-raspberry-pi-and-nvidia.html
#1   — Edited
The EZ-Robot camera is designed to connect only to an EZ-B v4 or Iotiny. It will not connect to USB (at least not without significant modifications).
ARC is compatible with any USB camera. Because there are millions of options for USB cameras, you can choose one that suits your requirements. However, you may be looking for one that fits the form factor (or is similar) to the EZ-Robot camera. The link you posted would work.
Alternatively, I like this camera because it has a 110-degree viewing angle. This is good for tracking: https://www.amazon.ca/Camera-Module-OV3660-USB2-0-Support/dp/B0878Z4MMB
I'll buy the one you recommend. Should work well.
Yeah, you'll like it. It is far superior to the ez-robot camera because of the 110degree view. You can see more of the world so it can detect objects easier. You don't get that "tunnel vision" from other cameras - where everything seems further than it is.
Awh, it's a Canadian Amazon item. I tried to buy this camera and they say they can't ship to my location in Florida, USA. I tried to find it on the US Amazon site but can't find it. Drat.
However, Walmart seems to have it available here in the US with free shipping. Looks like two weeks ship time though. Look here:
Walmart USB camera
Maybe there's something out there just as good as good that has faster delivery. Don't know. USB cameras are out of my wheelhouse.
Dave - just search Amazon for a 110 angle usb camera. See if something similar shows up
I was planning to connect this camera and the EZB to the USB hub of a Microsoft Surface Go2. I am concerned there might be a conflict or power issue with this arrangement. Has anyone done this successfully?
I do it all the time. I have a Microsoft Surface, and my test robots have a USB hub. The USB hub has lidar, Arduino, intel real sense, and a camera. The cable connecting to my PC is a USB 3 extension cable. I do that, so I can control the robot over USB rather than wifi because wifi is finicky and causes latency issues for my tests.
