DHT11 Temp & Humidity Sensor icon DHT11 Temp & Humidity Sensor — Read DHT11 temperature and humidity on Arduino (signal pin 4) using EZ-Genuino_DTH11_Uno firmware; exposes $Temp and $Humid variables. Try it →
Connecting EZ camera to PC via USB
Connecting EZ Camera To PC Via USB
Is is possible to connect the EZ camera to a PC via a USB port? Or is it easier to buy another one such as... https://core-electronics.com.au/usb-camera-for-raspberry-pi-and-nvidia.html
That's good to know. When I get my Surface Go 2 or 3, I will try and get everything working (for my Pepper robot).
@afcorson, if you'd like to use the EZ-Robot camera over USB check out this thread:
https://synthiam.com/Community/Questions/USB-connection-to-EZB-V4-21014
You just need to specifically find a PL2303HXD UART-TTL adapter. It is important that you find the "D" version, as you'll see on the thread.
If you'd like to change the Lens of the EZ-Robot camera to any angle you'd like, you can replace it with any M7 lens with 0.35 pitch.
