Audiotoolbox Plugin icon Audiotoolbox Plugin — Enable UWP voices, change default audio devices, capture audio and route it to EZB controllers with session tracking and device control. Try it →
Crashing While Using Ar Drone (1.0) Camera In ARC
Hey. Thanks for a great program, but i need some help.
I can control my AR DRONE 1.0 from the ARC. BUT, when i add camera controller component in the program it takes about 15-30 seconds, then the program crashes with the following error reports:
OS: Windows 8 64bit
- System
  - Provider
   [ Name]  Application Error
  - EventID 1000
   [ Qualifiers]  0
   Level 2
   Task 100
   Keywords 0x80000000000000
  - TimeCreated
   [ SystemTime]  2014-11-24T20:14:22.000000000Z
   EventRecordID 15106
   Channel Application
   Computer Zoulburner
   Security
- EventData
   ARC.exe
   2014.11.18.0
   546b9f48
   gdiplus.dll
   6.3.9600.17415
   54503bef
   c0000005
   000e9d85
   1bd0
   01d00822b25a65f7
   C:\Program Files (x86)\EZ-Robot Inc\EZ-Builder\EZ-Builder.exe
   C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.9600.17415_none_dad8722c5bcc2d8f\gdiplus.dll
   79e47332-7416-11e4-8312-50e549c467c1
This event is not displayed correctly because the underlying XML is not well formed. Below is the raw text of the event.
1026200x8000000000000015105ApplicationZoulburnerApplication: ARC.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.AccessViolationException Stack: at System.Drawing.SafeNativeMethods+Gdip.GdipDrawImageI(System.Runtime.InteropServices.HandleRef, System.Runtime.InteropServices.HandleRef, Int32, Int32) at System.Drawing.Graphics.DrawImage(System.Drawing.Image, Int32, Int32) at EZ_B.Camera.(System.Object) at System.Threading.ThreadHelper.ThreadStart_Context(System.Object) at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object) at System.Threading.ThreadHelper.ThreadStart(System.Object)
Anyone know what to do? Best regards. Fredrik Sweden
#18
Nope, Crashing Copy pasted from event viewer:
APPLICATION ERROR:
Faulting application name: ARC.exe, version: 2014.11.26.0, time stamp: 0x54764855
Faulting module name: gdiplus.dll, version: 6.3.9600.17415, time stamp: 0x54503bef
Exception code: 0xc0000005
Fault offset: 0x000e9d85
Faulting process id: 0x1c50
Faulting application start time: 0x01d009ca22d02c44
Faulting application path: C:\Program Files (x86)\EZ-Robot Inc\ARC.ARC.exe
Faulting module path: C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.9600.17415_none_dad8722c5bcc2d8f\gdiplus.dll
Report Id: a4d0eccd-75bd-11e4-8313-b8b52a55ab23
Faulting package full name:
Faulting package-relative application ID:
.NET RUNTIME
Stack:
#19
Interesting - okay... i'll look deeper into the code:)
#20
When you use the camera control, are any Tracking Modes specified? For example, do you have color tracking or anything checked?
#21
Yes. I have tracking enabled. even if i just have camera stream aktive and no tracking it still crashes.
#22
Probably won't make any difference but in your first post you stated you have Windows 8.... 8.1 is a free upgrade and you never know it might even fix your camera issues...
#23
Thx. But i have 8.1 :-) My bad.
I borrowed a windows 7 pc and it worked alot better on that one..
Sadla i am using windows 8.1 on my own pc..
#24
Is there a time difference between crashing with and without tracking modes specified?
