Roomba Tones icon Roomba Tones — Deprecated Roomba control; replaced by the iRobot Roomba Movement Panel for updated movement control. Try it →
Crashing While Using Ar Drone (1.0) Camera In ARC
Hey. Thanks for a great program, but i need some help.
I can control my AR DRONE 1.0 from the ARC. BUT, when i add camera controller component in the program it takes about 15-30 seconds, then the program crashes with the following error reports:
OS: Windows 8 64bit
- System
  - Provider
   [ Name]  Application Error
  - EventID 1000
   [ Qualifiers]  0
   Level 2
   Task 100
   Keywords 0x80000000000000
  - TimeCreated
   [ SystemTime]  2014-11-24T20:14:22.000000000Z
   EventRecordID 15106
   Channel Application
   Computer Zoulburner
   Security
- EventData
   ARC.exe
   2014.11.18.0
   546b9f48
   gdiplus.dll
   6.3.9600.17415
   54503bef
   c0000005
   000e9d85
   1bd0
   01d00822b25a65f7
   C:\Program Files (x86)\EZ-Robot Inc\EZ-Builder\EZ-Builder.exe
   C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.9600.17415_none_dad8722c5bcc2d8f\gdiplus.dll
   79e47332-7416-11e4-8312-50e549c467c1
This event is not displayed correctly because the underlying XML is not well formed. Below is the raw text of the event.
1026200x8000000000000015105ApplicationZoulburnerApplication: ARC.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.AccessViolationException Stack: at System.Drawing.SafeNativeMethods+Gdip.GdipDrawImageI(System.Runtime.InteropServices.HandleRef, System.Runtime.InteropServices.HandleRef, Int32, Int32) at System.Drawing.Graphics.DrawImage(System.Drawing.Image, Int32, Int32) at EZ_B.Camera.(System.Object) at System.Threading.ThreadHelper.ThreadStart_Context(System.Object) at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object) at System.Threading.ThreadHelper.ThreadStart(System.Object)
Anyone know what to do? Best regards. Fredrik Sweden
#33
I am not using any specific project.
I just add drone and camera and go to settings under drone control to change to V1 and Click connect. I haven't saved any project yet cause it crashes..
And yeah. Drone 1.0 it is :-)
#34
Seems its not an issue with my specific pc. I have tried several different pc's with same results.
Have a nice weekend and i hope you find the issue.
#35
Wonder if it's an issue with the country configuration? Do you have your locale set to Sweden and is the keyboard different?
I'm unable to reproduce the issue. We have many computers here and it works with all the ones I tested. I'm confuzzled
#36
I tried to change the region without luck.
But its still confusing that the ps eye is working flawless..
i begin to loose my hairXD
you are more then welcome to try my pc over teamviewer.
Have a good saturday!
#37
I'm working on it today further - losing my hair as well:)
#38
Maybe you sell Ar drone 2.0?
Im starting to give up..
#39
The Drone 2 is significantly more stable than the drone 1, and is compatible with the Flight Recorder/GPS chip which allows some really cool stuff, but don't upgrade just because of ARC. I am sure DJ will figure this out.
Ok. Thanks for your input.
I will wait a little more then..
