Servo Summary icon Servo Summary — All-in-one servo view showing and editing servo positions and speeds; add servos and resize the control to fit. Try it →
Custom Movement Panel V2 H-Bridge Support
I have a question about the ARC robot skill "Custom Movement Panel v2."
My robot is a two-wheel differential drive. The H-bridge I’m using requires a forward/reverse (direction) input pin and a PWM pin for each motor. Is there a convenient way to connect the "Custom Movement Panel v2" (or a similar Robot Skill) so it can control one direction pin and one PWM pin per motor?
Also, my H-bridge needs the PWM duty cycle to be limited to 95% or less to drive correctly - is that something the skill can accommodate?
For clarity: I haven’t specified how the H-bridge is connected yet. I’m planning to connect it via an EZB (so the H-bridge inputs would be wired to EZB digital and PWM outputs), but if other connection models are relevant (direct USB/serial driver or PC-connected hardware), I can provide details.
USB
Digital 21
Sabertooth Movement Panel by Dimension Engineering
Sabertooth movement panel: control two motors via Simplified Serial with variable speed sliders, movement buttons, and serial port options.
Dual H-Bridge w/PWM movement panel: control two DC motors' direction and speed via EZ-B PWM for responsive forward/reverse/turning.
Yes - the proven way in ARC is to use a Movement Panel skill that maps directly to your H-bridge inputs, rather than trying to force Custom Movement Panel v2 to behave like a generic motor driver.
Best approach
For a two-wheel differential drive H-bridge that needs:
  • 1 direction pin per motor
  • 1 PWM pin per motor
the best fit is usually:
That skill is designed for exactly this layout and is the standard ARC solution for an H-bridge with direction + PWM on each motor.
About Custom Movement Panel v2
Custom Movement Panel v2 is mainly for custom locomotion logic when you need to write your own scripts for movement directions. It’s powerful, but it is not the most convenient or standard choice for a normal dual H-bridge drive base.
If you use it, you would typically write scripts for:
  • Forward
  • Reverse
  • Left
  • Right
  • Stop
and inside those scripts you would manually set:
  • the direction pins with Digital.set()
  • the PWM pins with PWM.set()
That works, but it’s more work and easier to misconfigure than using the built-in H-bridge movement panel.
PWM limit to 95%
Yes, that can be accommodated.
Best options
You can do this in one of two ways:
  1. Use the skill’s PWM/speed settings if it exposes them
    • Some movement panels let you configure speed behavior in the skill settings.
  2. Cap PWM in script
    • If you are using Custom Movement Panel v2, just map the movement speed to a maximum of 95 instead of 100.
Example:
var speed = Utility.map(Movement.getSpeed(), 0, 255, 0, 95);
PWM.set(d4, speed);
PWM.set(d5, speed);
If you need to preserve left/right speed differences:
var leftSpeed = Utility.map(Movement.getSpeedLeft(), 0, 255, 0, 95);
var rightSpeed = Utility.map(Movement.getSpeedRight(), 0, 255, 0, 95);
PWM.set(d4, leftSpeed);
PWM.set(d5, rightSpeed);
If your H-bridge is driven by an EZB, the cleanest setup is:
  • 2 digital outputs for motor direction
  • 2 PWM outputs for motor speed
  • then use the Dual HBridge w/PWM skill
That way ARC handles the Movement Panel logic and you do not need to reinvent the locomotion layer.
If you want to use a custom script anyway
Then yes, you can absolutely do it with Custom Movement Panel v2, and the correct pattern is:
  • Forward script: set both motors forward, apply PWM
  • Reverse script: set both motors reverse, apply PWM
  • Left/Right: vary one side or reverse one side depending on your drive design
  • Stop: set PWM to 0 and disable direction outputs
What I’d recommend
If your robot is a standard differential drive, I strongly recommend:
  • Use Dual HBridge w/PWM
  • Limit speed in the skill or by script if needed
  • Avoid Custom Movement Panel v2 unless you need custom steering logic or special behavior
That’s the standard ARC way and will save you time.
Quick question
What H-bridge board are you using, and are you planning to drive it from:
  • an EZB directly, or
  • another controller over serial/USB?
If you tell me the exact board model and your desired port mapping, I can give you the exact ARC setup and pin assignments.
If this is for custom code, the ARC AI Assistant inside ARC can also help generate the movement scripts for you directly:
Yeah athena is right. just use the hbridge pwm movement panel. that kind of motor controller you're using is a bit strange as it only has 1 input for direction instead of 2. but that'll still work, just connect the one wire to one of the outputs of the ezb for the hbridge.
the hbridge outputs a logic for direction. so like
STOP
0
0
FORWARD
1
0
REVERSE
0
1
but in your case, you'd just connect to one of the digital pins for the hbridge.
As for limiting the speed - that can be done via robot skills that control the speed. For example, if using a joystick robot skill, specify the max speed. But if you want a change to have a hard limit of 95%, we'd have to whip up a robot skill change for you.
