RGB Animator icon RGB Animator — Create custom animations for JD Humanoid's 18 RGB Eyes LEDs via I2C - per-LED color frames, transitions, pauses, scripting and real-time preview. Try it →
Yes, press the rotate button when the bit is highlighted green.
Thanks dj, I had later figured out that it was my screen resolution hiding the rotate function
No problem:) What was your screen resolution? Did you get a warning when loading the design function that the screen resolution as too low? I think it warns if the resolution is less than 1024x768 or something similar..
yes.i did get a warining but i did not know it would do that. thanks
