SSC-32 Servo Controller V2 icon SSC-32 Servo Controller V2 — Bridge ARC to Lynxmotion SSC-32: maps V0-V31 to SSC-32 channels for reliable, high-performance serial control via USB, EZB/Arduino UART. Try it →
Yes, press the rotate button when the bit is highlighted green.
Thanks dj, I had later figured out that it was my screen resolution hiding the rotate function
No problem:) What was your screen resolution? Did you get a warning when loading the design function that the screen resolution as too low? I think it warns if the resolution is less than 1024x768 or something similar..
yes.i did get a warining but i did not know it would do that. thanks
