Neopixel Ring icon Neopixel Ring — ARC UI for onboard computers to control NeoPixel rings via serial: test/run patterns, preview and copy Arduino serial commands, includes sample code. Try it →
feganmeister
yes i can upload my project
#18
@nomad LOL.... how do you manage these things.... you broke ARC....:P
#19
Hi Nomad,
Do you have an anti-virus program installed on your Win 7 PC, or do you have a wired ethernet connection going to it?
#20
In case others aren't aware of this, @nomad had huge issues with the wifi previously. His EZ-B is in client mode and it must remain in client mode, it will not work in AP mode due to some networking issue he has (nothing to do with the EZ-B itself).
@Nomad, the debug you copied and pasted is stating that it's timed out before it made connection. This is before any control, feature (or feather) or anything. The issue is not ARC but your network.
Based on previous (and long drawn out) topics I would suggest sticking to one PC which you know works. There is no real need to use another PC for testing. If you must use another PC for testing follow Jeremie's advice and check on virus protection and multiple networks.
Also, I believe feganmeister was requesting that you post the project rather than just asking if you could post it. You didn't upload it to your reply... (However I don't believe the issue to be the project)
jeremie
wired whit the adaptor from ENgenius.but i need to connect thru android. thats the problem,i cant get on that webserver.
rr i spend all day making the kd and chest from parts i have let printed. it was really bad day.and now just for two servo's averything gets stress
am done whit new updates from ARC.it gets worse avery time
#22
You'll find the ARC updates make it better every time not worse. It is not the software at fault here, if it was then there would be others complaining of the same problems.
sorry rich but thats not my exsperiance.
ps.ok i found the webserver back.
#24
Not updating ARC is not going to solve the problems, there is a problem there which needs solving. Masking it will not solve it. Asking for help and ignoring it will not solve it. Not taking the advice given will not solve it.
