Dual Hbridge icon Dual Hbridge — Two-channel Dual H-Bridge movement panel to control two DC motors (on/off) for forward, reverse, left, right via EZ-B digital ports; no PWM speed. Try it →
Click on Tutorials, Click on ARC Manual, Check the page for the Distance Sensor/Collision Detection.
It's simple, 2 servo cables, one has power, ground and signal, the other just signal. Solder the power & ground to the vcc & ground on the sensor. Solder one signal to the trig and the other to the echo.
