Miscellaneous Utility Plugin icon Miscellaneous Utility Plugin — ARC utilities: DataQuery for SQL/ODBC/OLEDB/Excel with parameterized queries returning array variables; Ticks/Millis timing functions. Try it →
Click on Tutorials, Click on ARC Manual, Check the page for the Distance Sensor/Collision Detection.
It's simple, 2 servo cables, one has power, ground and signal, the other just signal. Solder the power & ground to the vcc & ground on the sensor. Solder one signal to the trig and the other to the echo.
