Dual Axis Compass Module, Is There A Video On How To Wire?
Dual Axis compass module, is there a Video on how to wire?
D.J. Maybe when you get back from the show and settle down, I would like to see a short video on how to wire this. I see the pinouts going from the board, but where do i hook them to the EZB?
Just a little schematic would help.
Thanks,
Oh, maybe you also have one on hooking up the PIR, I have one of those also.
Thanks,
Mel
it hook up to the I2C port on EZB
Right. But is there a schematic? I see on the little board an RX and TX, Vcc+ and Ground. How many wires do I need. I think the I2C has only 3 wires. I have been in electronics for 41 years. I have heard of I2c before, but this is my first time to actually use it.
you may not have the right compass board this is one type
compass board rx and tx is ttl or serial board,not I2C its 4 wires 5v or 3 volt,gnd and SCL and SDA
Yep. This is the same one that is in your add. It is a 24 pin and looks sort of like the basic stamp. It says it is Ic2. Maybe this board is both.
BTW, how is GART comming along? What about the turtlebot Software? It has been a couple or three weeks hasn't it?
if the same one you hook up gnd to gnd ,5 volt to 5 volts,SCL to SCL,SDA to SDA software havent had the chance to work on it yet,very busy
will it say scl,sda on the ezboard?
yes,there is 4 pins near bottom of board labeled,the same pins go to the compass board
So, I probably only need those pins and not any more of the 24 pins?
OK, I see them. Now, I want to hook the compass, but I also have a PIR unit to hook there. So, would I hook both units in parallel to make them both work?
Thanks,
Mel
