Camera NMS Pose icon Camera NMS Pose — Overhead camera tracks a glyph to give precise robot pose to ARC's NMS for multi-camera indoor/outdoor navigation and waypoint control Try it →
Dual Axis Compass Module, Is There A Video On How To Wire?
Dual Axis compass module, is there a Video on how to wire?
D.J. Maybe when you get back from the show and settle down, I would like to see a short video on how to wire this. I see the pinouts going from the board, but where do i hook them to the EZB?
Just a little schematic would help.
Thanks,
Oh, maybe you also have one on hooking up the PIR, I have one of those also.
Thanks,
Mel
is the PIR I2C bus or analog or digital,if I2C same pins can hook up many I2C sensors up to the same pins what kind of PIR sensor do you have
I believe it to be IC2 type. The connections on it are:
There is a jumper that says H & L.
then there is a 3pin connector that says: -,+, and OUT. I believe it came from Parallax.
That is all the connectors. Don't know how to hook it.
Mel
I looked on the Parallax sight and found it. It was the cheapest one that I could find. $7.95. It must be digital because you hook the +5 volts and ground and then ONE pin turns either High or Low if it sees something. Must be digital.
then you hook it up to the digital pin
