SMTP Client icon SMTP Client — Send SMTP email (text or camera images) from ARC robots via ControlCommand; configure SMTP/auth and sender; saves credentials in project. Try it →
Spain
I have bought two esc like these very good price, with heat sink and fan, your esc have looked like a plane because it leads to external heat sink, I guess the figure is exaggerated 300A, but I think so Ahun they are the best option price amps.
ESC
@ ww321q Are you using them with the EZ Board? If so, are they working OK?
Spain
Yes, I have proven with ez-b and working properly.
I only tested them as Buster is just getting started.I tested with a 7.4 volt lipo. They seemed to work great:)
That's good to know. Thanks.
These Banebots
ESC's are controlled with PWM. So.... I could have 20 of these (if I ever needed that many:) ) hooked up to the EZ-Board.
Is this correct?
I'm thinking the ESCs like I used can be speed controlled by standard servo control panel. JW:)
