Wavefront icon Wavefront — Wavefront grid planner computes collision-free, deterministic paths from start to goal using known occupancy maps for indoor robots. Try it →
Spain
rgordon: If you could have connected many of these esc the board ez-b, are controlled by PWM with a standard servo control from ARC and can be used when the ESC have reverse gear or have the two directions of rotation, the central position of the servo position that does not act the ESC (approximately) I have disconnected the red wire connector that goes to the ez-b, is recommended because the ESC has a BEC that supplies 5v when connected to radicontrol receptors, such as ez-b has its own supply voltage does not need the red wire . Greetings.
Netherlands
This might help, it's a little bit dated since all the updates but it might helpLink
Thanks! That helps a lot :P
