Autonomous AI icon Autonomous AI — Autonomous AI robot skill with vision, speech, movement, animations, and self-directed task execution powered by LLMs. Try it →
Extended Batt Outside Robot
i had so much fun thismorning playing whit jd. untill the batt was empty.so my question is,there are bigger batt, with higher MAH 2200, could there made a connection in jd, to disconnect the batt inside thru a swiths and connect the batt, from outside jd thru a connector.
dont know if there are any with more MAH
That battery will work fine and will give you a much longer run time, but it won't fit inside JD or any of the other Revolution robots either....
rr
its not intended to put inside jd.but i need to be able to disconnect the one thats inside jd.and connect outher one.is there a way to do that.
you can use a 3 pole switch or solder a plug on both batteries so you can unplug one and plug in the other....
i was thinking off a tripple swits 0/A OR B A for original batt and B for the exterior batt. so B has to disconnect A
are there in the same size as jd?
