Extended Batt Outside Robot
i had so much fun thismorning playing whit jd. untill the batt was empty.so my question is,there are bigger batt, with higher MAH 2200, could there made a connection in jd, to disconnect the batt inside thru a swiths and connect the batt, from outside jd thru a connector.
dont know if there are any with more MAH
dj
thats a good link,thanks
the batt in the link last only 19 minites
@Nomad? 19mins? When using it where? How long it lasts wouldn't that depend on what you are powering and the amount of current that is being drawn? How do you know that anyway, have you tested one?
rr
the seller provided this info.
@Nomad 19mins attached to what? He owns a JD? An LED only last 19mins or a power hungry quadcopter lasts only 19mins? Do you understand that how long a battery lasts depends on what it is powering... The battery DJ posted a link to is double the mAh (2800) of the stock battery that comes with JD.... Quick math will tell you that this battery will last twice as long in JD than that of the stock 1300mah battery that comes with it
you can see the link.i shows helicopters race cars.
#15
Yes, but do those race cars and quad copters use the same amount of power that JD uses?.... I'll try one more time....
JD's battery is 1300mAh = about 30 mins of runtime...
The battery DJ linked to has 2800mAh = 60 mins of runtime in JD
Do you understand now? That battery will give you twice the runtime in JD...
yes that i understand.thank you
