Hola
Hopefully this is easy. Can the standard EZ servos (builders kit) safely run at 5 volts (but plenty of amps)?
Thanks,
- Scott
Slide Script
— Adjust a numeric variable via slider (0-1000) with customizable min/max, center button and scripts triggered on value change or bonus button press.
Hola
Thanks,
Yep over 4.8V is fine.
And you'll find the specifications for the servo on all product pages that use the servos. Here's a direct link to the product that you're inquiring about. Scroll down and you will find the servo specifications: https://synthiam.com/Shop/AccessoriesDetails.aspx?prevCat=101&productNumber=2
