EZMQTT Broker icon EZMQTT Broker — Local MQTT broker for ARC: host pub/sub messaging on TCP port 1883, relay topics between publisher and subscriber clients. Try it →
No - what version of the ez-b v4 do you have? It tells you when connection occurs in ARC. If it's a /2 then you can once the firmware has been released for USB connectivity.
i'm not sure about the EZB v4 FW, but i just got it a week ago.
Depends where you got it from. Check the status window when ARC connects to it. It'll say the version.
If i'm looking in the right place (the popup box in the bottom) after connection it shows EZ-B v4 ID: ........
@robotdude If you have a v4/2 you wouldn't have to use the scan tool to locate it... It will automatically pop up in the box labelled Discovery (right side) in the connection control (click on the wifi antenna looking icon)
Look in the status window that pops up at the bottom when you connect to the ez-b. You can copy and paste the contents if you need us to read it for you. It'll read CONNECTED, check what version it says. Or paste the contents here.
this is what i'm getting:
EZB 0: EZB 1: EZB 2: EZB 3: EZB 4: Screen Resolution: 1920x1080 (96x96 dpi) Attempting connection on 192.168.1.1:23 Connected to 192.168.1.1:23 Reports EZB v4 OS With Comm 1 EZ-B v4 ID: 38-50-0-0-46-255-60-57-58-38-39-39 Setting battery monitor voltage: 7 Setting battery protection: True Setting i2c rate: 100000 EZ-B voltage is 13.348571904 EZ-B temperature is 25.39318697205904656C
Perfect... You have a COMM 1 ez-b, which means you will need a EZ-B v4/2 Comm Upgrade that was released yesterday. The USB firmware hasn't been released yet. Shouldn't be much longer.
