Perfect! Right now Data is offline until the USB update. I cannot connect remotely to the ARC computer if the Wifi is used by the EZB4.
You know... you can put EZ-B into client mode so both the EZ-B and the computer are on the same WiFi network..... See https://synthiam.com/Tutorials/Lesson/15?courseId=5
Yes i know that...:) Because our high-security login process to our WiFi network we cannot make the EZB basic client to login. Besides, why to use WiFi if you can connect the EZB directly to the computer that controls it?
Gotcha. There are other solutions, depending on the network's subnet, but probably not worth pursuing since USB connection is on the way. I have a use case as well so am waiting (im)patiently for the USB adapter.
Any updates with the EZ-B v4/2 Comm USB firmware support?
The USB comm usb interface and firmware will be posted when it is available
