Servo Sketch 3D icon Servo Sketch 3D — Real-time 3D servo visualization with motion trails, interactive camera controls and clear trail for ARC debugging and analysis. Try it →
Ez-Bit Heavy Duty Servo Does Not Fit Kit Servo
Hello,
I just printed the EZ-Bit Heavy Duty servo 90degrees. Then I tried fitting it to the EZ-Robot servos that came with the kit and it does not fit. I was under the impression since there where no EZ-Bit brackets for the standard servo that this EZ-Bit would fit.
Are the dimensions of the heavy duty servo different from the kit servo? If so then why is there no EZ-Bit for the standard servo thats comes with the kit?
Thanks
Well I already saw that 3D model in the library, its just a 3D model of the standard kit servo.
I already have the standard servo that came with the kit and the Heavy Duty EZ-Bit I printed does not fit it.
Are the dimensions of the heavy duty servo different from the kit servo? If so then why is there no EZ-Bit for the Standard servo thats comes with the kit?
I don't know anything about 3d printing but can you load the stls in the printers software check the dimensions in there? Maybe they're off. I've had a few stl import issues into ARC. My sketchup stl exports didn't import properly so I had to switch to 123d Design.
Well I think the EZ-Bit printed the right dimension, my hunch is that the heavy duty servo EZ-Bit does not fit the Standard Servo.
Thats why I wanted to confirm. And also was wondering why there is no EZ-Bit to fit the standard servo that comes with the kit?
I'll add standard servo brackets tomorow
Thanks DJ for the clarification
@antron007 have you downloaded the beta auto desk 123d , they fixed some glitches the standard version had and I really like the user interface better.
@jstarne1 I'll have to check. I just dled it to start working with Ez-Bits a few weeks ago. Just to be clear, you are talking beta right? I think I have the current stable. I'll check for an update or find the beta when I get home this evening. Thanks.
@DJ Thanks for forthcoming brackets;)
