Myo Gesture Armband icon Myo Gesture Armband — Map Myo armband gestures and accelerometer to servos and ARC scripts for arm-mimic control; supports multiple armbands. Try it →
Ez-Bit Heavy Duty Servo Does Not Fit Kit Servo
Hello,
I just printed the EZ-Bit Heavy Duty servo 90degrees. Then I tried fitting it to the EZ-Robot servos that came with the kit and it does not fit. I was under the impression since there where no EZ-Bit brackets for the standard servo that this EZ-Bit would fit.
Are the dimensions of the heavy duty servo different from the kit servo? If so then why is there no EZ-Bit for the standard servo thats comes with the kit?
Thanks
Yes the beta. The original appears to have some bugs in a few controls.
@Josh, I'm going to hunt it down now. 123D is a resource hog and has crashed on me a few times but other than that I'm digging it.
Really? It's only crashed on me twice (both times while doing the exact same thing - selecting multiple (around 30) circle sketches for extruding)
Have you tried the online version through Chrome? It's how I made the text inside my MG90s servo since text isn't in the current stable release (not sure about the beta, I was unaware of it until now).
Well, I had a bunch of stuff running so I'm not complaining it crashed. I know how it happened;) Beta9 is no loner available:( Anyone have any links to a copy floating around the net? AutoDesk no longer has it on their site.
No I haven't tried it through chrome yet. I'll have to check that out. Thanks @Rich!
Standard EZ-Robot servo brackets are now in the EZ-Cloud. Sync your library
