Joystick (Direct Input) icon Joystick (Direct Input) — DirectInput joystick control for ARC: drive movement panels, control servos, assign button scripts, variable speed and rumble feedback. Try it →
Ezbv Not Connecting
Ezbv Not Connecting
my appolegies to ask this again.i need an answer how to figur out, if the ezbv is damaged.i bouth a new one,and set it on Engenius. withs is just recently all set up by a pc repairman. the ezbv4 will not connect to the wifi,no matter what i try. it works in AP mode ,but i dont like this way.
my pc is set to englich language. other robot connect to wifi,but not for long.am out off ideas. any pointers anyone ?thanks.
It is possible that the PC repair guy changed your network ssid. You will need to connect the ez-b to the new network ssid if this is the case.
Otherwise, I would press the reset button and follow the client mode connection process again.
hi i try all tree i could think off.also reset button.nothing. one doesn connect to wifi ,but connect to AP all others connect few sec then disconnect. is it possible the engenius is damaged ?
If your phone or other wifi devices can connect to your wifi, then the router is not to blame. Run me through what is happening when you press the reset button and try to connect in client mode. 1.What is said by the ez-b? 2.What is the led color? 3. What is connected to the ez-b?
i got all the voices on ezbv,its bue blinking AP mode. reset button doesn work.am unable to connect to your internet. only the head of jd.
Have you connected to it in so mode and tried to change the web server? It may need to be changed or reconfigured. As I said, perhaps the computer guy changed your wifi name and password? If not I would still check that the ez-b is connecting to the proper wifi.
hi mazeHorizontech
i have an acces point Engenius where al wifi devices are on. we started from the start with a new webpage what i can see is the engenius signal dropping very fast and low. i gess that cause the disconnecting ezbv4.my provider says, two router or acces points together will cause problems anyway. now the ezbv4 dont come out the ap mode when i press reset button.
thank you for your support.
seems i have a missing part in the ezbv4.unthinkeble
the yellow polyfuse is not there
Your ISP doesn't know what they are talking about. This is the way that companies are setup all over the world. WiFi access points that are not a part of the router is a standard practice/best practice on many levels. It is a bit more complicated, but has been setup for you multiple times and has worked great for you. Something has changed in your environment. I can't help set it up again because I have way too much going on right now.
What I suspect is that the radio channel setting has been switched from finding an open signal to a set channel. I also suspect that someone has moved in close to you who is using the same channel, or that both your router and access point have been set to use the same channel. This is why yours was setup to find and use an open channel.
My wife goes in for a major surgery tomorrow. It is mothers day and I will be spending time with the family today and taking care of her after the surgery. If you don't have a resolution in about a week, I should have time to connect and get everything set up again. This is all dependent on what happens when I get back to work in about a week and if there are no complications with the surgery.
I do find it weird that you don't see the poly fuse though.
