Cognitive Vision icon Cognitive Vision — Microsoft Cognitive Vision integration for ARC: real-time object, face, emotion detection, OCR, confidence data and script-triggered robot actions. Try it →
Ezbv Not Connecting
Ezbv Not Connecting
my appolegies to ask this again.i need an answer how to figur out, if the ezbv is damaged.i bouth a new one,and set it on Engenius. withs is just recently all set up by a pc repairman. the ezbv4 will not connect to the wifi,no matter what i try. it works in AP mode ,but i dont like this way.
my pc is set to englich language. other robot connect to wifi,but not for long.am out off ideas. any pointers anyone ?thanks.
#25
Im failing to understand the correlation between the missing poly fuse and the not connecting to your network. If it is powering on its not a fusing issue. My guess is that ez robot has made a design change and is now relying on the power base fuse rather than the redundant poly fuse. Hopefully someone from ez will chime in.
also i notest the temp from the ezbv4 is higher then normal some 26.15 i just revieve mail i get a new one,hope it goes well. itry to connect the nao on engenius and that went perfect. ezbv4 board is total diff then normal,if you see the pic original dj and mine.
the problem was missing polyfuse.jason confirmed this.
thanks all for responding
new ezbv is in the mail
#28
fantastic, I am glad that the issue was identified. makes ya wonder how they missed it but people are people:)
jstarne
i was amaze to see no polyfuse.i cant believe that this is not on purpose , done.avery firm has many quality controls with devices to check there, produckts.before leaving the factory.i could understand a missing screw. but these boards are made by automatic robots.yep sombody got drunk that day.
#30
It is very strange that it would work in AP mode but not Client with no polyfuse. I am surprised that it worked at all.
I guess we'll see when you get the replacement if you still need help with client mode.
hi alan
i now perfect how to connect an ezbv ,special with an iphone its very easy. i was amaze not to get it out ap mode.and i must say in ap mode i didn disconnect ones.and also long time playing to.do the temp was higher then normal 26.18 . wel tomorow i get big box with lot of ez parts.and i need to order some by jason soon to.another thing ,my nao has not on engenius and he connected perfect. there is no chedule on the engenius.but i had a great time in ap mode,and i now how to connect that one too,good practise.
jason confirmed that it normal ,the new ezbv4 has no polyfuse. still the blue led starts blinking first.so i think you guys has to , check this out.seems another approuch is needed. to set it up.
