Sound Script icon Sound Script — Replaced by Sound Script (Speech Script) robot skill; see Synthiam's Speech Script support page. Try it →
Foscam Camera Get Commands
Hi,how do i set up HTTP GET commands for foscam camera pan/tilt so when i steer to left cam turns left,steer right cam turns right and center cam goes center. I have my project on cloud (RC 4x4) make changes if u like. here is a command https://my-ip-port/decoder_control.cgi?command=35&onestep=5&user=admin&pwd=admin
all i have to do is change the command number to move to different spot thanks
Hello Pittom, what kind of camera is it?
And do you have a link to a list of commands?
It may be a stupid question and please excuse me if it is but you are replacing my-ip-port with the IP and port of the camera (i.e. 192.168.1.2:80) aren't you?
Also, is the url correct? i.e. is decoder_control.cgi?command=35... an actual command recognised by the camera to, I assume in this case, pan the camera right.
Also check the username and password are correct for the camera.
I know the HTTPGet(url) command works perfectly as I just tested it and made ARC turn my lights off using a url (which is good to know as that means ARC can be used to control EventGhost via HTTP easily, which in turn can control pretty much anything), so as far as I can tell it's a problem with the url you are using.
yes i replaced ip and just tested it again but when i put in joystick in button 1 i go to save it and error unknow command
i got it to work thanks
Hello,
What did you do to get this to work? Would you be interested in sharing the ARC script code that you used to get your foscam camera to move left when you moved your robot left, etc. Also I assume that you can control tilt also.
Do you also know the commands to turn the ir leds on and off? In the list of commands would it be the digital on & off commands?
I am using the foscam F19831p IP camera but I would assume the commands are the same.
What I want to do is do the same thing mentioned in your thread but I would be using one of the movement panels in ARC PC and also want it to work with mobile app. Interested in what you have come up with?
I am not very familiar with web and html programming and using the httpget command but willing to dig in and learn......Rick B.:)
