Avatar JD icon Avatar JD — 3D Avatar JD simulator with bidirectional servo sync, action sequencing, $SIM_ scripting, EZ-B emulator support and pose/movement visualization Try it →
Foscam Camera Get Commands
Hi,how do i set up HTTP GET commands for foscam camera pan/tilt so when i steer to left cam turns left,steer right cam turns right and center cam goes center. I have my project on cloud (RC 4x4) make changes if u like. here is a command https://my-ip-port/decoder_control.cgi?command=35&onestep=5&user=admin&pwd=admin
all i have to do is change the command number to move to different spot thanks
Hi , I have not been playing with it for over a year, I am going to start to work on it in a week or so. I thought I had it saved in the public cloud under name crawler, if it is not there I will find it and let you know how to do it.
Pittom
Thanks Much Pittom ! I would like to be able to turn camera in same direction as robot like you are doing. Also would be nice to be able to view camera and do all this control in the mobile app but from previous threads I pretty much understand why it can't really be done. I did manage to find the commands to turn IR LEDS on and off. I have the foscam F19831p IP camera and it is set for JPEG snapshot mode. Would like to be able to see video in ARC video control, but not sure of command line to enter in control. Any help on viewing the video in ARC would also be much appreciated. Thanks again and looking forward to seeing what you have done and how you did it..Rick B.:)
Hello Pittom,
Just wondering if you found your crawler foscam scripts for viewing and controlling the foscam functions? Look forward to be able to view and control foscam camera via ez-scripting. Thanks much ! Rick:)
i did not find it yet,i had it on ez cloud under rc 4x4 but can not find it. i am checking my hard drives. read this thread and that is how i did it,just had user and password problem.
still looking
Thanks much Pittom ! I will give it a shot and keep you posted...Rick:)
