How Many Motor Controllers Can You Connect To EZ-B? (The 2.5A ones you can buy in the EZ-Robot store)
RCStartToFinish
— Edited
3 Participants
Drone Collision
— Add HC-SR04 ultrasonic sensors with an EZ-B to AR Parrot Drone v1/v2 for collision detection and avoidance
Each controller takes 4 ports there are 20 ports on the ez-b so 5.
thank you so much One More Question
How would i connect a higher amp 12v dc motor to the EZ-B?
The motor would get it's power from the motor controller. The motor controller gets 5V signal from the EZ-B and motor power from an alternate source. So just make sure the motor controller can handle that much power and hook it up to a 12V source.
Thank YOU!!!
What is the torque on a standard servo?
If you can have more than one H-Bridge motor controller, how do you control them if only one Movement Panel Control is allowed?
I not sure cause i dont have ez-b yet but i think you can have more than one
