Kinect Xbox 360 Depth Mapping icon Kinect Xbox 360 Depth Mapping — Converts Xbox 360 Kinect depth frames into NMS obstacle scans for ARC path planning, SLAM, and obstacle avoidance. Try it →
Each controller takes 4 ports there are 20 ports on the ez-b so 5.
How would i connect a higher amp 12v dc motor to the EZ-B?
The motor would get it's power from the motor controller. The motor controller gets 5V signal from the EZ-B and motor power from an alternate source. So just make sure the motor controller can handle that much power and hook it up to a 12V source.
If you can have more than one H-Bridge motor controller, how do you control them if only one Movement Panel Control is allowed?
I not sure cause i dont have ez-b yet but i think you can have more than one
