Neopixel Blaster icon Neopixel Blaster — DIY NeoPixel Blaster for ARC - open-source controller for up to 8×80 LEDs (640), port‑0 onboard RGB, color control via ControlCommand Try it →
How To Let Jd Turn Left Or Right
i notest that jd cant turn.so i start thinking whits i mostly do. what do you think off this 3d part.you can mount something in front and back,(rgb-sonar.) let him turn left or right,and he gets a little taler.i notest whit the exsperiment, that jf or another robot have a problem whit the hiel comming together. so maybe we can solve this by letting jd take little steps,2 to make a kwart off a circle.
what do you think.thank for reading.
Its here as one of the controls of the ARC software. I noticed it wail working with the ezb v3. and was wondering if it is still the recommended hardware for the ezb 4 as i would like to add one to Hexi and JD.
here is on on Ebay
somone will answer your question,i gess iff its still availeble it will work whit ez-b4 to i gess.
ah magnetic sensors.love it.
you can answer by click on the ?
That compass will always be supported, but we have been looking into a few others and have not made a decision yet.
Many addons are being developed which will be released before Christmas:)
GPS. Compass. Localized positioning system. Ez smart servos. Accelerometer. Gyro. And a few adapter boards to support/dominate other products.
I think a gyro would be better than a compass for precise turning... Unless you need to turn to a precise heading, in which case a GPS would be better...
@DJ... Hmmm, can't wait for your Localized positioning system and the Ez smart servos sound very intriguing...
Dj, your team and your self should make like an Ez-Neural Network for artificial intelligence. I think that would be awesome
Actually gps can't tell what direction you are facing unless you are moving at least 1km/hr. That is why most modern Gps and smartphones have electronic compasses. Many will auto calibrate the compass when you are moving, so if they lose calibration from magnetic interference they will get it back automagically.
Thanks Alan... forgot about that... I should have remember being that I have a couple of handheld GPS units that I use....
#16
Not to mention GPS doesn't work too well indoors:)
