Movement Script icon Movement Script — Trigger direction-specific scripts when ARC movement panels change; assign scripts per direction/stop, access direction and speed (JS/Python/EZ). Try it →
How To Let Jd Turn Left Or Right
i notest that jd cant turn.so i start thinking whits i mostly do. what do you think off this 3d part.you can mount something in front and back,(rgb-sonar.) let him turn left or right,and he gets a little taler.i notest whit the exsperiment, that jf or another robot have a problem whit the hiel comming together. so maybe we can solve this by letting jd take little steps,2 to make a kwart off a circle.
what do you think.thank for reading.
#17
@Rich... I have a Garmin Montana 600, which appears to have a supper sensitive receiver as it can grab signals and maintain a fix even in my basement...
#18
My Smartphones that use aGPS also have no trouble getting a fix indoors, although at best, an aGPS receiver has about 1 meter accuracy. Need DGPS and long sample times to do better than that. A GPS without cell tower assistance will be 2-3 meters under optimum conditions.
There are some designs for "indoor GPS" that we might start seeing in large buildings like malls and convention centers. Will probably use a combination of WiFi and/or Bluetooth triangulation and require smartphone software or new receivers to work. Standards are a long way off, but some pioneers may start deploying their own solutions before any standards are published.
Earlier designs used transmitters that spoofed or re-transmitted the GPS signals indoors, but at least in the USA they ran afoul of the FCC and DOD so those ideas are essentially dead.
