EZ-B V3 Configuration icon EZ-B V3 Configuration — Manage EZ-B hardware settings: edit Bluetooth name and apply updates to restore altered configurations. Try it →
I Need Inspiration
I Need Inspiration
I have 2 robots in the process. Ones a toy tank and the others my dewy robot. I'm stuck in a rut.
Trying to make the tank turret turn is a big problem because I have no space inside. I want it to be a clean design.
Dewy needs to be painted, and then have his neck (which has nothing to mount to) rigged up.
I've set them aside for too long and I need to get back at them. So, if there's anything you think will help me reach that goal, post it. PLEASE.
Thanks.
hi,
take a picture of each one.
for the tank, from the top no turrent on, but another picture of turrent up side down.
why you ask, so we maybe able to suggest what to do.
same two pictures of dewy.
j
Taking pics is always a good idea. Theres two main ways to make a turret turn. Center mount a servo to mount it to , or you can make a track and bearings that glide on a circular rim. On this rim you can have a gear motor with small rubber tire or go to the trouble of making a gear ring to affix to the inside of the turret. Main advantage of a gear ring is the motor can be mounted on any edge all the way around the body. As long as the pinion or tire can meet ab edge it can turn your turret. Post pics and i can be more specific.
you can place the servo els where and connect it whit a gear or belt.
Do you have any space in the turret itself? Maybe you can mount the servo or micro servo in the turret instead (upside down) and attach it to the chassis that way? It would mean you would have to find a way to route the servo wire out of the way, though...
Here's the problems:
DEWY:
The "90* servo" needs to stick out almost all the way while the rotating servo can stay in the body.(Reference part Roli's neck assembly)
THE HEAVY SHOOTER PROJECT:
The tank turret needs to turn 180 * from left to right. there is virtually no space in the body of the tank but the turret has lots of space. The turret has the camera in it whick those cables almost fill the hole of which I can put wires in but a servo wire could probably fit.(reference part: mini servo)
The robots which are currently sitting happily on a wooden box.
Ideas?
Thanks. Tech
the turet comes ontop grey part?
you will need gears or a belt.can you place the servo's below?
Nomad, as stated I have absolutely no space in the main tank body. I tried a gear setup but failed miserably.
