Soundboard (EZB) icon Soundboard (EZB) — Play WAV/MP3 via EZ-B v4, manage tracks, add timed scripts for synced robot actions, control via ControlCommand(), volume and clipping indicators. Try it →
I Need Inspiration
I Need Inspiration
I have 2 robots in the process. Ones a toy tank and the others my dewy robot. I'm stuck in a rut.
Trying to make the tank turret turn is a big problem because I have no space inside. I want it to be a clean design.
Dewy needs to be painted, and then have his neck (which has nothing to mount to) rigged up.
I've set them aside for too long and I need to get back at them. So, if there's anything you think will help me reach that goal, post it. PLEASE.
Thanks.
can you make the top a little longer by putting exstra piece off pipe in?
Ok , I believe some painters tape and epoxy resin will allow you to make a place to mount a servo. If needed i can take pics later but basically you tape off the neck opening and turn the body upside down. Then fill until about 1/4 inch thick with liquid epoxy from the inside. Then remove tape once hard and you will have a hocky puck sized place to cut a 20 x 40mm slot for a RC servo to center mount and that can be the mount for your turret.
Thanks for the ideas. I'm going to take another look at everything and hope to fall on an idea,
