Roll Pitch Yaw icon Roll Pitch Yaw — Rotate and position camera or object with roll/pitch/yaw controls; save camera settings; bind or monitor a 3-value EZ-Script array for live rotation. Try it →
Resolved Resolved by Jeremie!
Is This Warenty
Is This Warenty
i make another topic about the batteries cause this can be a case of warenty. the chargers says output 12 volt,i get 12.22 volt .i think thats ok the charger gifs 11.20 something to low.so i look at the batt in jd win8, and it wil not charge,green led goes out.i also see some punctering in the batt, from i gess factory.i made a video.the balancers gifs 8.22 volt on 1.15 hour, and led goes out.gess also perfect.when i messure the wire itself ,i get , about 12.20 volt.so can this be warenty.also i think if the other jd's dont have it. i got now 4 death batteries and 1 bad charger.i use the robots 1 or 2 times, a week.
i have 3 batts stil here ,the others are in the container for batts.
here a video from the 3 i still have.you can clearly see the seal is broken, and they are puffy.also punctering optop from swelling in the chest.
#36
Personally, I think threatening EZ with a smear campaign over batteries that they don't even manufacture is bad form.
Repeatedly discharging and charging a LiPo battery without giving it sufficient rest time in between is going to kill it eventually.
#37
@nomad... You have to wonder why you have so many problems that the rest of us don't have.... Be patient and let ezb look into your issues.... I would also warn you about trashing ez robot... because you can't undo it if you "burn your bridges" here.... Right now it is only 7am where the ez robot office is... No one will be in the office for another few hours yet...
Zap Brannigan
i did gif the batts 30 min rest avery time.you chould rea the hole topic ok.
#39
There really is no point in any further responses here until Nomad contact James to be perfectly honest.
EZ-Robot have been very accommodating so far with lots of good suggestions and requests for answers however it seems that is not cutting it and from the looks of things, rubbing the wrong way.
Nomad, I urge you to stop, read what both DJ and Jeremie have posted, contact James once they are open and see what they can do to rectify this. Threats will certainly not help your situation but will only rub those loyal EZ-Robot users the wrong way.
Be patient, be calm, go have a coffee, wait for EZ-Robot to open for the week and contact James as suggested. EZ-Robot will always do whatever they can to rectify any situation, you know this, we know this, a quick scan of the forums shows this.
However, if you want to wind up burning all of your bridges and finding yourself with no help and no leg to stand on feel free to continue with your pathetic threats.
rich
dj allreddy said it no warrenty.atleast jeremie say something usefull.
and pathetic threats ,seeing you in the shower is pathetic.
you see things only from your side.look it from my side.
trying to explain how i got 6 bad batts.you may by 2 batts per order. thats 3 months before i can do anything.and sinds many getting involved. and make things more diff am gonna close this topic. mad mad mad
