Resolved Resolved by Jeremie!
Is This Warenty
Is This Warenty
i make another topic about the batteries cause this can be a case of warenty. the chargers says output 12 volt,i get 12.22 volt .i think thats ok the charger gifs 11.20 something to low.so i look at the batt in jd win8, and it wil not charge,green led goes out.i also see some punctering in the batt, from i gess factory.i made a video.the balancers gifs 8.22 volt on 1.15 hour, and led goes out.gess also perfect.when i messure the wire itself ,i get , about 12.20 volt.so can this be warenty.also i think if the other jd's dont have it. i got now 4 death batteries and 1 bad charger.i use the robots 1 or 2 times, a week.
#41
Have you even spoken to James yet? Have you taken DJ's advice and purchased a high quality charger?
I see things clearly from both sides. I have absolutely no affiliation with EZ-Robot. What I do have though is respect for the community and for EZ-Robot.
Until you a) do what people advise you! and b) apologise for the attempted insults for no reason I am unable to offer any further help, guidance or advice.
Good luck with the smear campaign...
yes i bout new charger and bad.i made pics for jeremie . i wil by the batts myself,just want to be sure it dont happen again. apologise :D
read topic is closed
RICH
my appolegies to you for the words i said to you. there is no excuse to make it good. sometimes i act (mostly ) stupid, i was not going to do a smear campagne. just place a cartoon from the ok coral. this doesn mean all is fine.hope you except my appolegies.
patrick
