EDU Activity Editor icon EDU Activity Editor — Design, edit and export structured Blockly-based lessons, groups and hints for ARC Lite Portable; supports rich HTML, images, JSON import/export. Try it →
Joystick/movement Panel Question
Joystick/Movement Panel Question
So I am puzzled... I have my Movement Panel working and it works fine using arrow keys ... But when I use the joystick I can see the GU lighting up in corespondece with joystick movent and the Movement Panel GU even lights up same as if I was using the arrow keys... Only difference is nothing happens with robot.. but again if I put joystick down and hit arrow keys the bot will move. ? Note: that sometimes within same instance periodically I will get movement from bot with joystick but that is only temp.. What puzzles me the most is I could see trouble shooting it if when the joystick is used nothing happens on the GU... But everything is lighting up
Okay, a bit of troubleshooting first.
Are you using a joystick control window (Add control, Misc, Joystick) as well as the movement panel.
If so, and you have selected the joystick from the drop down menu, is the "Joystick #1 controls movement panel" box checked? If you have a tick (like in the photo), this will control a movement panel.
Yes to all. When I use the joystick it moves on the EZ control screen and even lights up the Movement Panel as if I were pushing the buttons without a joystick.. Only difference is not does not move when the joystick is used
A bit more troubleshooting then. Are you using the mini joystick you posted about the other day?
When in the joystick config screen, on the "Buttons" tab, press all the joystick buttons to see if they all highlight. If they do you might have to configure the forward, reverse, turn (D-pad) controls from there.
If the D-pad buttons don't highlight, here's something else. Is it a H-Bridge motor controller your controlling, or servos? If it is Servos you might have to uncheck the box (in the photo) and configure the servos in the menu.
On other thing you can try I forgot to mention, is to make a note of your Movement Panel settings, delete the movement panel, then add and configure it again. I think someone else tried this a while back and it worked for them.
I have done all of that:(
Can you post your project? It sounds like something else is stopping the movement when the joystick is used.
If the Movement Panel is responding to the joystick so show whatever the Movement Panel is set to move.
Not sure if this is relevant to your situation, but I had basically the same issue with my Lynxmotion Joystick... It has a analog button on the joystick... The joystick would only drive the Movement Panel if I pressed the analog button...
So i am at work and dont have my file... its on my thumb drive at home... but here is a video of the issue.
Rich I merged you ramp script to my R2 project .. and like I said it works as long as I hit the arrow keys..
