Camera NMS Pose icon Camera NMS Pose — Overhead camera tracks a glyph to give precise robot pose to ARC's NMS for multi-camera indoor/outdoor navigation and waypoint control Try it →
Joystick/movement Panel Question
Joystick/Movement Panel Question
So I am puzzled... I have my Movement Panel working and it works fine using arrow keys ... But when I use the joystick I can see the GU lighting up in corespondece with joystick movent and the Movement Panel GU even lights up same as if I was using the arrow keys... Only difference is nothing happens with robot.. but again if I put joystick down and hit arrow keys the bot will move. ? Note: that sometimes within same instance periodically I will get movement from bot with joystick but that is only temp.. What puzzles me the most is I could see trouble shooting it if when the joystick is used nothing happens on the GU... But everything is lighting up
#25
@Rich, your ramping script should work on any port... I am running my sabertooth with @Jayutmb's project on port D23
#26
@Richard R I see that my sloppy layout has not gone unnoticed LOL! that is for the Dome of the R2 unit, that is a syren 10 motor card running the one motor that controls the domes "spin" I have not gotten around to cleaning the dome stuff up until i fix this control issue ( and no sadly I have not had a chance to try any of yall's great ideas yet to fix it sadly)
