On Variable Changed icon On Variable Changed — Run scripts automatically when specified ARC variables change; define variable-to-script pairs, monitor status, and trigger actions. Try it →
L298n H-bridge
Setting Up L298n H-Bridge This tutorial assumes only a single combined speed control for both motors. For independent speed of each motor the tutorial will be slightly different - See post #2 of this topic.
Assuming ports D15, D16, D17, D18 & D19 D15 Signal > Left Trigger A (In 1) D16 Signal > Left Trigger B (In 2) D17 Signal > Right Trigger A (In 3) D18 Signal > Right Trigger B (In 4)
D19 VCC > H-Bridge 5V D19 Ground > H-Bridge Ground D19 Signal > H-Bridge ENA & ENB
D19 Signal will need to be connected to 2 pins on the H-Bridge and the jumpers on the H-Bridge removed. I made a Y cable out of a couple of jumper cables.
Connect the positive of the battery to the H-Bridge VCC
Connect motor 1 to the Out 1 and Out 2 terminals Connect motor 2 to the Out 3 and Out 4 terminals
In ARC add a 4 Wire H-Bridge control and a PWM control.
Set up the H-Bridge control as the above D15 to D18 on LTA, LTB, RTA and RTB Set up the PWM control to D19
To use, set the PWM to 100% (or a lower value if you want it slower) - I have mine set to 100% in an init script that is run on successful connection of the EZ-B. Use the H-Bridge control and the motors should move.
Here is a project with both controls added, you can save it and merge it with your project (or open it and test the H-Bridge). It's also accessible in ARC by opening from the cloud.
Note: The PWM wire is optional. If you wanted to save a digital port and lose speed control you could connect any of D15 to D18's VCC to the H-Bridge 5V and any of the D15 to D18's Ground to the H-Bridge Ground. Keep the jumpers on between ENA and 5v and ENB and 5v.
If your H-Bridge looks different, they are pretty much all much of a muchness. A H-Bridge generally has 4 inputs to control the 2 motors plus 1 or 2 inputs for speed control. The same principle as above can be applied.
Signal wires from Digital ports to each of the inputs to control the motors. Generally labeled In1 to In4 or AIn1, AIn2, BIn1 and BIn2. Signal wires (this can be combined for 1 port if you don't want individual speed control from side to side) for the PWM or speed. Generally labelled as ENa and ENb. +5V or VIn is generally the 5V from the EZ-B Vm is generally the supply to the motors taken from the battery. Ground is always Ground, taken from any ground since it's a common ground.
A simple truth table for how the H-Bridge works.
 In4 | In3 | In2 | In1 | Function
  0  |  0  |  0  |  0  | Stop/Free Wheel
  0  |  0  |  0  |  1  | Motor 1 Forward
  0  |  0  |  1  |  0  | Motor 1 Reverse
  0  |  0  |  1  |  1  | Motor 1 Brake
  0  |  1  |  0  |  0  | Motor 2 Forward
  1  |  0  |  0  |  0  | Motor 2 Reverse
  1  |  1  |  0  |  0  | Motor 2 Brake
So to use that on the robot, setting digital to on (1) and off (0) as follows
  0  |  1  |  0  |  1  | Robot Forward
  1  |  0  |  1  |  0  | Robot Reverse
  1  |  0  |  0  |  1  | Robot Turn Left (or right depending on motor orientation)
  0  |  1  |  1  |  0  | Robot Turn Right (or left depending on motor orientation)
  0  |  0  |  0  |  0  | Robot Stop
EZ-B V4 Usage
With the EZ-B V4 there is a slight difference when connecting the L298n H-Bridge up in that the Vcc pins of the V4 have the same voltage as VIn i.e. if you supply the EZ-B V4 with a 7.4v 2s LiPo battery you will get 7.4v on the Vcc pins of the EZ-B.
The L298n H-Bridge, as previously explained has a terminal for +5V which, on the EZ-B V3 was fine to supply from one of the digital ports Vcc however with the V4 this is not the case.
Rather than supply the L298n with +5V we need to not connect this terminal and press the switch on the H-Bridge so that it uses it's on board regulators to provide its own 5V from the Vcc supplied.
All other connections remain as previously explained.
Pushing this button will enable the on board regulators. When enabled it may indicate so with a red LED.
On the EZ-B side, the connections would be pretty much as previously with the exception of the Vcc. On upgrading my test bot I simply disconnected the Vcc on the H-Bridge side so that my connections wouldn't require changing.
On the H-Bridge side, connections remained the same as previously however the +5V is disconnected.
That's all there is to it.:)
Update: 17/06/2014 (or 06/17/2014 if you write your dates wrong...)
Alternative wiring for a simpler method
The connections on the L298n are simply;
Vcc = Motor Supply Positive Gnd = Motor Supply Ground (ensure this is common if using more than one supply) +5V = Not Connected
In1 = Digital Port Signal (i.e. D8) In2 = Digital Port Signal (i.e. D9) In3 = Digital Port Signal (i.e. D10) In4 = Digital Port Signal (i.e. D11) EnA = Digital Port Signal (i.e. D12)* EnB = Digital Port Signal (i.e. D13)*
  • EnA & EnB connections optional for speed control, If speed control is not required connect the two jumpers which come with the L298n to link EnA to the +5v pin to it's right and EnB to the +5v pin to it's left. If combined speed control is required (i.e. one speed control for both channels) a Y-cable can be used to connect both EnA and EnB to one Digital Port Signal (i.e. D12).
No ground or Vcc from the EZ-B to the L298n is required if you have a single source for both EZ-B and L298n or if you have a common ground.
You must make sure you press the switch to enable the on board 5V regulator circuit otherwise it will not operate
Some photos (I'll change them once I get chance to edit and tidy them up but no idea when I'll get the chance so here's the unedited ones).
The L298n in it's stock state
The L298n wired power connections
The L298n wired for no speed control
The EZ-B V4 wired for no speed control
The L298n with the jumpers removed
The L298n wired for common speed control (1 PWM adjusts the speed of both channels). White wires is a Y cable, 2 to 1 with the 2 at the L298n end
The EZ-B V4 wired for common speed control (1 PWM adjusts the speed of both channels). White wire is a Y cable, 2 to 1 with the 1 at the EZ-B V4 end
The L298n wired for independent speed control
The EZ-B V4 wired for independent speed control
#49
Trying to hookup a Sabertooth 2x25v2 to 2 motors (Wheelchair motors). Has anyone done this before? Not sure what DIP switch setting to use on Sabertooth or how one might configure for multi control for joystick. I have been successful with H-Bridge on smaller projects before but this is a little different. Thanks!
#50
Jackphiiips, Did you read the documentation on this controller? DE has a very clear manual with steps on how to setup and do what you're wanting. They also have a dip switch wizard to assist you. Here's a couple links to follow that will get you going. If you've already read through all this then let us know what you've tried and where you are having trouble:
Look under the documentation section down the page for lots of links to help:
www.dimensionengineering.com/products/sabertooth2x25
Other good links on that page: Manual
Did Switch Wizard
#51
@castlephelps I guess I should have been clearer. Many H-bridges can be supported by ARC. Approximately 8 single H-bridges or 4 Dual H-bridges via scripting. It's true that there is only one H-Bridge Movement Panel supported per project.
You see, the H-Bridge Movement Panel is designed for a Dual H-Bridge system where 2 motors have to work in tandem (both move at the same time). This is ideal for Robot drive systems but not ideal for Robot Arms and legs. If you have multiple motors you need to use with the drive system you'll likely just want to use a higher rated H-Bridge and connect the motors in parallel on each H-Bridge channel. It is extremely rare that a robot would ever need 2 or more independent drive systems so that is why only one exists in ARC.
If you are using single H-bridges, for robot arms let's say, you likely don't want to use a control that puts 2 motors in tandem but rather you'll want to have them operate independently from each other.
A single H-bridge control is likely what you are looking for and at the moment it doesn't seem to exist in ARC (besides the continuous rotation servo control). I think this is a great idea for a plug-in......hint hint Anyone up for the challenge?
#52
Hi Dave,
Thanks for links and the help.
I have used the H-Bridge before with success and now I need to use the Sabertooth for 2 wheel chair motors.
I have been trying to use the Sabertooth serial with no success. I believe I need 2 outputs to control motors separately.
I need to be able use both motors separately so I can make turns with the 2 motors.
I was able to do this easily with H-Bridge.
Sabretooth seems way to go with these motor, I may run at 24 volts in future.
Any suggestions?
Thanks.
#53
The sabertooth is a breeze to use compared to an H-bridge... 2 wire connection, simple serial commands... They are way expensive but I use them exclusively in my projects... The H-bridge is great for small robot projects...
#54
Hi Richard,
In what way is it a breeze?
How did you connect to EZ?
By that I mean what EZ control did or are you using?
Thanks.
#55
You connect it to any of the ports... Just 2 wires... ground and signal... all ports can send serial commands on the V4... You can also use the UART ports as well... Sabertooth set up for 38400 buad (Dave gave you the links to the manual)
sendserial(D0,38400,0) #this stops the motors on both channels
#56
You do not connect the red power from EZ D0?
