Omron HVC-P2 (Second Camera) icon Omron HVC-P2 (Second Camera) — Windows ARC plugin for Omron HVC-P/HVC-P2: Python-based face/body/hand detection, gaze, age/gender, expressions and recognition; dual-camera support. Try it →
L298n H-bridge
Setting Up L298n H-Bridge This tutorial assumes only a single combined speed control for both motors. For independent speed of each motor the tutorial will be slightly different - See post #2 of this topic.
Assuming ports D15, D16, D17, D18 & D19 D15 Signal > Left Trigger A (In 1) D16 Signal > Left Trigger B (In 2) D17 Signal > Right Trigger A (In 3) D18 Signal > Right Trigger B (In 4)
D19 VCC > H-Bridge 5V D19 Ground > H-Bridge Ground D19 Signal > H-Bridge ENA & ENB
D19 Signal will need to be connected to 2 pins on the H-Bridge and the jumpers on the H-Bridge removed. I made a Y cable out of a couple of jumper cables.
Connect the positive of the battery to the H-Bridge VCC
Connect motor 1 to the Out 1 and Out 2 terminals Connect motor 2 to the Out 3 and Out 4 terminals
In ARC add a 4 Wire H-Bridge control and a PWM control.
Set up the H-Bridge control as the above D15 to D18 on LTA, LTB, RTA and RTB Set up the PWM control to D19
To use, set the PWM to 100% (or a lower value if you want it slower) - I have mine set to 100% in an init script that is run on successful connection of the EZ-B. Use the H-Bridge control and the motors should move.
Here is a project with both controls added, you can save it and merge it with your project (or open it and test the H-Bridge). It's also accessible in ARC by opening from the cloud.
Note: The PWM wire is optional. If you wanted to save a digital port and lose speed control you could connect any of D15 to D18's VCC to the H-Bridge 5V and any of the D15 to D18's Ground to the H-Bridge Ground. Keep the jumpers on between ENA and 5v and ENB and 5v.
If your H-Bridge looks different, they are pretty much all much of a muchness. A H-Bridge generally has 4 inputs to control the 2 motors plus 1 or 2 inputs for speed control. The same principle as above can be applied.
Signal wires from Digital ports to each of the inputs to control the motors. Generally labeled In1 to In4 or AIn1, AIn2, BIn1 and BIn2. Signal wires (this can be combined for 1 port if you don't want individual speed control from side to side) for the PWM or speed. Generally labelled as ENa and ENb. +5V or VIn is generally the 5V from the EZ-B Vm is generally the supply to the motors taken from the battery. Ground is always Ground, taken from any ground since it's a common ground.
A simple truth table for how the H-Bridge works.
 In4 | In3 | In2 | In1 | Function
  0  |  0  |  0  |  0  | Stop/Free Wheel
  0  |  0  |  0  |  1  | Motor 1 Forward
  0  |  0  |  1  |  0  | Motor 1 Reverse
  0  |  0  |  1  |  1  | Motor 1 Brake
  0  |  1  |  0  |  0  | Motor 2 Forward
  1  |  0  |  0  |  0  | Motor 2 Reverse
  1  |  1  |  0  |  0  | Motor 2 Brake
So to use that on the robot, setting digital to on (1) and off (0) as follows
  0  |  1  |  0  |  1  | Robot Forward
  1  |  0  |  1  |  0  | Robot Reverse
  1  |  0  |  0  |  1  | Robot Turn Left (or right depending on motor orientation)
  0  |  1  |  1  |  0  | Robot Turn Right (or left depending on motor orientation)
  0  |  0  |  0  |  0  | Robot Stop
EZ-B V4 Usage
With the EZ-B V4 there is a slight difference when connecting the L298n H-Bridge up in that the Vcc pins of the V4 have the same voltage as VIn i.e. if you supply the EZ-B V4 with a 7.4v 2s LiPo battery you will get 7.4v on the Vcc pins of the EZ-B.
The L298n H-Bridge, as previously explained has a terminal for +5V which, on the EZ-B V3 was fine to supply from one of the digital ports Vcc however with the V4 this is not the case.
Rather than supply the L298n with +5V we need to not connect this terminal and press the switch on the H-Bridge so that it uses it's on board regulators to provide its own 5V from the Vcc supplied.
All other connections remain as previously explained.
Pushing this button will enable the on board regulators. When enabled it may indicate so with a red LED.
On the EZ-B side, the connections would be pretty much as previously with the exception of the Vcc. On upgrading my test bot I simply disconnected the Vcc on the H-Bridge side so that my connections wouldn't require changing.
On the H-Bridge side, connections remained the same as previously however the +5V is disconnected.
That's all there is to it.:)
Update: 17/06/2014 (or 06/17/2014 if you write your dates wrong...)
Alternative wiring for a simpler method
The connections on the L298n are simply;
Vcc = Motor Supply Positive Gnd = Motor Supply Ground (ensure this is common if using more than one supply) +5V = Not Connected
In1 = Digital Port Signal (i.e. D8) In2 = Digital Port Signal (i.e. D9) In3 = Digital Port Signal (i.e. D10) In4 = Digital Port Signal (i.e. D11) EnA = Digital Port Signal (i.e. D12)* EnB = Digital Port Signal (i.e. D13)*
  • EnA & EnB connections optional for speed control, If speed control is not required connect the two jumpers which come with the L298n to link EnA to the +5v pin to it's right and EnB to the +5v pin to it's left. If combined speed control is required (i.e. one speed control for both channels) a Y-cable can be used to connect both EnA and EnB to one Digital Port Signal (i.e. D12).
No ground or Vcc from the EZ-B to the L298n is required if you have a single source for both EZ-B and L298n or if you have a common ground.
You must make sure you press the switch to enable the on board 5V regulator circuit otherwise it will not operate
Some photos (I'll change them once I get chance to edit and tidy them up but no idea when I'll get the chance so here's the unedited ones).
The L298n in it's stock state
The L298n wired power connections
The L298n wired for no speed control
The EZ-B V4 wired for no speed control
The L298n with the jumpers removed
The L298n wired for common speed control (1 PWM adjusts the speed of both channels). White wires is a Y cable, 2 to 1 with the 2 at the L298n end
The EZ-B V4 wired for common speed control (1 PWM adjusts the speed of both channels). White wire is a Y cable, 2 to 1 with the 1 at the EZ-B V4 end
The L298n wired for independent speed control
The EZ-B V4 wired for independent speed control
#65
Hello. Newbie to EZ-B here. Not new to electronics/robotics.
I am unable to get my motors to react. I am using two power supplies, so I wanted to make sure that connecting one of the ground pins on the top of the EZ-B to the ground of the power input of the board is sufficient.
If it is, I do not know why things aren't working.
I have the PWM bridge. I have LTA->D8, LTB->D9, LPWM->D12,RTA->D10,RTB->D11,RPWM->D13.
I have hooked the motor battery directly to the motors to confirm they are working.
What should I do first to troubleshoot this?
Thanks
#66
ground to a ground pin on the EZ-B should be fine.
Some LN298's seem to have the 5v button wired backwards, so even though this tutorial says it should be in the down position, try it in the up position.
That was it. I put the button in the up position, the 5V LED lit, and the motors started responding to the controls.
Thank you.
#68
I really appreciated Rich's tutorial on H Bridge configuration and wiring to the EZ B. I have several of the following 12v Dual Channel DC Motor Drive Module H Bridge with PWM Input on hand, but the input on them is different than the H Bridge Rich used. I admit that I am new to using an H Bridge as most of my past robot builds were glorified R/C puppets using an R/C PWM microcontroller.
That being said, I am hoping someone can give me some direction on the pin out on this H Bridge and how to interface it with the EZ B.
1 VCC Isolated positive power input, compatible with 3.3V, 5V power supply 2 PWM1 M1 channel duty cycle modulation input, high-speed isolation, bandwidth 50MHz 3 INA1 M1 Channel Control Logic Input A. 4 INB1 M1 Channel Control Logic Input B. 5 GND Isolated power input 6 VCC Isolated positive power input, compatible with 3.3V, 5V power supply 7 PWM2 M2 channel duty cycle modulation input, high-speed isolation, bandwidth 50MHz 8 INA2 M2 channel control logic input A. 9 INB2 M2 channel control logic input B.
  1. GND Isolated power input
purple
your qr code says ez robot.you chould never post a qr code.everybody can read , them ,scan them.
#70
that hbridge connects the same way the ezrobot hbridge does. Follow the ezrobot hbridge connection diagram and you’re good to go.
#71
Thank you DJ. My HBridge has 10 pins however. Rich's example has an HBridge with 8 pins. What pair do I ignore? I guess a better question is if there is a diagram that cross-maps the pins on this type of HBridge to the connections on an 8 pin HBridge or to the EZB?
#72
It's the same wiring, exactly.... except the 3-5v dc connection. That can come from the power of an ADC port. Here's wiring from the ez-robot HBridge PWM control: https://synthiam.com/Support?id=192
DC3-5 -> EZ-B ADC 0 RED (power) PWM1 -> D4 INA1 -> D1 INB1 -> D0
PWM2 -> D5 INA2 -> D2 INB2 -> D3
And the motors... M1A -> motor M1B -> motor
M2A -> motor M2B -> motor
And the power for the motors P- -> your battery negative P+ -> your battery positive
