Debug icon Debug — Central ARC debug window routing logs; shows UTC date/time, Windows/ARC/skill/hardware info, version/settings, with copy and clear. Try it →
Meet The Smart Saltwater Aquarium Powered By Ez Robot
Ez Robot community I wanted to introduce my latest application of this system. Some members hear already know I keep two salt water aquariums one coral which unfortunately died off and my predator tank. Sea life needs delicate balance maintained in their little ecosystem. Things like light spectrum , temperature, ph balance , current of water , nitrate and ammonia levels and calcium levels. These things take a practiced hand to maintain. I am building a new system and using ez b to monitor salinity, nitrates and ammonia, temp , water current flow and the ph. The ADC ports are useful for these and EZ board can control the current and switching to a backup power supply ( a apc for computers inside the cabinet to keep ezb and pumps powered). Also the ezb can turn on and off night , morning , day , and evening lighting settings. With a custom injection device im designing ezb can provide nutrients , calcium and even medicine if levels are out of wack. I started the build today and I am very excited!
#41
Here is my roommates tank system that he rigged relays and timers to do what he wants. Fortunately I have EZB:)
Ok 17 dollars shipped. For this mini explorer submarine. Where the center led is im thinking is great for a camera!
#44
Three color light on the way
Also current generators
#45
Usually a tank of my size would have two current generators. I only bought one now but I will probably get a second. I will update everyone if I do..
#46
Ok tiny update. Total of 4 current generator pumps are on their way. Two will be on each end of the tank. I will simulate wave alternating currents by each set of pumps running 20 to 30 seconds then switching to the opposite side of the tanks pumps and pushing back agian for another 20 to 30 seconds. This is an uncommon marine tank setup because of complexity and all the equipment you would need to buy. Thanks to a handful of relays and switching transistors ezb can control all these effortlessly!
