EZ-B V4 Info icon EZ-B V4 Info — Displays EZ-B v4 internal temperature and battery voltage, shows built-in battery monitor and LiPo protection settings in Connection Control. Try it →
Meet The Smart Saltwater Aquarium Powered By Ez Robot
Ez Robot community I wanted to introduce my latest application of this system. Some members hear already know I keep two salt water aquariums one coral which unfortunately died off and my predator tank. Sea life needs delicate balance maintained in their little ecosystem. Things like light spectrum , temperature, ph balance , current of water , nitrate and ammonia levels and calcium levels. These things take a practiced hand to maintain. I am building a new system and using ez b to monitor salinity, nitrates and ammonia, temp , water current flow and the ph. The ADC ports are useful for these and EZ board can control the current and switching to a backup power supply ( a apc for computers inside the cabinet to keep ezb and pumps powered). Also the ezb can turn on and off night , morning , day , and evening lighting settings. With a custom injection device im designing ezb can provide nutrients , calcium and even medicine if levels are out of wack. I started the build today and I am very excited!
#57
Its only noticable with flash but looks like I have a tiny bit of overspray of primer. No problem i must repaint this thing with a good indoor paint because this stuff was horrible. So I will get a oil or water based paint instead of latex . Also inside the cabinet I am getting a couple baking pans to use a drip pans when I replace filter media and the inside of the cabinet will be sprayed with liquid rubber.
#58
In this system I have a chato algae canister , gfo canister , carbon canister. One is empty at the moment. Once I added the material I got lots of air in the system and now its pushing lots of bubbles.
#59
Ok fixed the bubbles till all the air is out if the system...
The chato needs light to live and grow and it will be a few days till equipment gets here so im using a house hold energy saving bulb at the moment. Because the cabinet is tinted even with lights on inside the cabinet it blocks most the light.:)
This is a pic showing the regular lamp lighting the chato algae
This is the door closed , there are a couple tiny cracks I will cover but mostly it looks good..
#60
More updates will come tommorow with plans for mounting ezb in a dry safe place as well as the relays that will be used to allow ezb to control everything.
#61
After just one night with new filter media . Wow this will be crystal clear.
Ok equipment is on the way so progress will stand still till then.
Blue submarine (to encase ez cam) arrival usps Nov 9
T5 Marine parts light UPS Nov 8
4 powerhead 350 gph pumps (to make waves) Nov 9
125 snails (aid the automatic system as natural cleaners)
Tip220 switching transistors to control ac power relays as interface between ezb and relays) nov 7
#63
Good news switching transistors are here and the submarine... sub seems smaller than pictured.
Its big enough for a cam inside but I would need to gut the electronics to make room. Go figure lol.
